barty
Sept 9, 2014 20:34:36 GMT
does anyone of you cleaver lot know if the driveshafts from a mk1 micra (K10 i think) fit a mk2 micra (K11 i think) i have a early micra ( to be scrapped if no one wants it)and now a newer on but the new one has a noisey CV joint and i was wondering if the driveshafts can be swapped over
Sept 10, 2014 18:34:20 GMT
Early K11's have the same gearbox, I reckon they should be the same.
micra drive shaftsDez
@dez
Club Retro Rides Member 34
Sept 10, 2014 18:45:22 GMT
no. different trackwidth. not by much mind, just enough to make it not go. at least it was on the k11 engined k10 we built for a mate of mine, which i now own. we ended up swapping the entire k11 package in and cutting and shutting the lower arms to make it work.
@dez
Sept 10, 2014 18:46:52 GMT
on another note, id possibly be interested in your micra as i need some panels, drop me a PM with the details.
barty
Sept 11, 2014 11:31:08 GMT
message sent to Dez and thanks to everyone for the advise.I suppose i could check part numbers for the early micra against the later ones to see if they are the same, but then if someone want the K10 i would rather let it go complete
