Finlay
Sept 10, 2014 15:37:37 GMT
Hi all
In process of putting an S2000 engine in my 76 chevette, wondering what axles i should be looking at, i believe a manta A bolts right up, not sure about manta B, icould fit an atlas but would need lots o mods, chevette HS are pricey and very rare
Any other thoughts or advice from anyone would be much appriciated :-)
Cheers
Finlay
Cheers
Finlay
95 clio 16V - modded track/road car
95 clio Williams 2 - restored to standard
95 TVR Griff 500 - Taraka engine upgrade
MNR Vortx (kit car) - busa power
Chevette SR20 engine
MK2 Escort GM LS1
Chevette XE (building)
Sept 10, 2014 20:17:58 GMT
The Isuzu Piazza axle is almost a straight swap apart from changing the Panhard rod round, and it comes with and LSD. The Scimitar Se5a Salisbury 4HA axle was a popular swap at one time if you go to a 5 link set up. The Se6a axle is easier to find but is wider so you need Group 4 or HSR arches. Anything can be made to fit if you are handy with a welder, so Volvo axles are a cheap option. The S2000 doesn't have that much torque so I'd go for the Piazza axle.
V8 MGB GT sprint and track V8 Ford Pilot Woodie project 1971 Early Bay VW camper
edwell
Sept 11, 2014 12:56:46 GMT
A B axle will fit but they are wider so you are limited with wheel choice. I have seen one that ran a B axle with VW golf steels on the rear and standard arches. A piazza one would be better though (if you can find one).
jasonj
Sept 13, 2014 8:05:46 GMT
The Piazza axles are really rare now. Not sure how reliable a manta B axle will be with 240 BHP running through it. If it were me I would source the Scimitar Se5a axle. Very strong, 5 linked and a massive range of final drives from 3.3 to 5.1. Power lock LSD's were used in these axles in a lot of Jags so they are relatively cheap and easy to come by. I'm using the wider Se6 axle in my Ascona.
Team Supercharged Opel Ascona 400. 294bhp - 235 lb/ft
