Sept 14, 2014 2:46:42 GMT
Hey there, does anyone know where i can get one of those tools for fitting the chrome trim into the window screen rubber? I'm putting my mk3 cortina back together after its new paint, I have new screen rubbers and the chrome trim but cant seem to find the tool for inserting it! By the way I will be posting a full resto picture thread once completed :-) Thanks people
Sept 14, 2014 7:22:25 GMT
Look for a lock strip tool !
Sept 14, 2014 7:24:42 GMT
I used a wooden peg when i did mine on the escort
Sent from my GT-I9505 using proboards
Sept 14, 2014 9:29:39 GMT
Sept 14, 2014 12:39:53 GMT
Thanks alot guys, searching for "lock strip tool" did bring up a tool on amazon but it was only on the US site! Cheers for the offer curlie467, but I'm down by Birmingham! I did find a tool on a mini site but it said it was "mini specific" do u know if they're the same size as the ford trim? I also found a nice looking tool on Woolies site but it was £29.99 + p&p!!! I thought that was abit steep! Thanks again people, Ant
93fxdl
Enter your message here...
Sept 14, 2014 17:54:48 GMT
We made our own to fit the strip to a triumph 2000, used a piece of wire coathanger bent to shape then gripped in a pair of vice grips Ttfn Glenn
Sept 14, 2014 19:25:09 GMT
Use a ring spanner & loads of silicone spray or dishwashing fluid or liquid soap Don't use mineral oil, it may damage the rubber. And do it in warm conditions, that's not a job to do with a cold, hard rubber seal...
Sept 14, 2014 22:12:56 GMT
Bookmarked I can't help but I'm looking for ideas (or volunteers around Tyneside ) to fit new rubber on my Hunter. Not cheap but Frost are UK based and have a tool with lots of different bits & thingies (thingys ?) for £33 www.frost.co.ukor look for "windscreen insertion tool" on Ebay to see what shape the wire needs to be bent to make a tool Hope you get sorted
Sept 14, 2014 23:14:20 GMT
barty
Sept 15, 2014 11:18:02 GMT
might be worth asking a screen fitter, prob do it for the price of a pint
Sept 15, 2014 13:14:16 GMT
might be worth asking a screen fitter, prob do it for the price of a pint Good idea, I tried it £45 if he does it at my home/work, £25 if I take it to his workshop. Have been trying for more than a month to catch him at his workshop
barty
Sept 15, 2014 20:00:43 GMT
£25 got to be worth it
Sept 15, 2014 21:04:03 GMT
I'm a windscreen tech and will do it for beer token if you close enough to me ..I'm based around chester ?
bortaf
Sept 16, 2014 20:27:46 GMT
Is it the wide chrone trim or the usuall locking strip type? if it's the wide type, good luck !!!! If it's the usuall narrow type and your near N London you can borrow my insert tool ?
R.I.P photobucket
Sept 17, 2014 20:58:56 GMT
I have been a windscreen fitter for the last 26 year's and have a few tools for fitting chrome inserts, one of my favourites is my smoothed flat blade screw drivers, franklin do a couple of insert tools of different sizes and are exactly the same as my old ladaw one's, make sure you seal the screen before you replace the insert or you might kick the insert out have to do it again, 3M 08509 sealer is fantastic stuff.
Last Edit: Sept 17, 2014 21:00:04 GMT by rusty998
MK2 Cortina Estate
