Due to illness i have for sale my Hillman Imp Californian which only requires finishing.Most parts are either new or refurbished.
All suspension components have been epoxy powder coated and polybushed. Springs are Monte Carlo and dampers are GAZ adjustable units. It has a front mounted radiator which only requires boxing in.
Wheels are new 13" Ultralites with new Yokohama A539 tyres. There is a new front disc brake kit and all flexy brake lines are Goodridge braided.
The engine is a Cashmore 930 fitted with twin SU carbs. The head was fitted with phosphor bronze valve guides with sport valves, new seats and sport springs. Camshaft is sport too.The exhaust is a Janspeed tubular with a modified Ducati silencer. The area above the engine is insulated with heat reflective foil insulation as well as the inside of the car behind the rear seat area.
The engine will require the head gasket replacing as i used a cheap one which is now leaking.
The fuel pump is electric with a fuel filter and pressure regulator. Headlights are Cibie quartz. Seats are Lotus Elise leather. Passenger seat requires bolting in. The steering arms are fully adjustable with the Ford Fiesta track rod conversion. Body work is solid as well as the cills and underside.
I have the original seats and the front and rear chrome bumpers as well as the original radiator etc.
Please ask for more info if required. Car will require trailering or a car transporter to take away.
