Mk1 Ford Escort 1300L 2 door steel bubble arched shell for sale, with no running gear included in the sale. It was first registered 05/04/1974. I have the V5 present and in my name, the car has been in dry storage since 2005 and has one ignition key and two door keys.
It has slight rusting as can be expected but it comes with most of the panels to replace these areas, ie the floor pans have few holes in and new pans are supplied.
Panels included but not fitted to the shell:
New front panel
Two new reproduction front wings with steel bubble arches fitted
Two new front floor pans
Two new rear floor pans
Two new seat rails
Two new flitch panels
New heater bowl
Auto tunnel from Expressed Steel
Two new front chassis leg repair panels
Inner rear o/s quarter panel
Original boot lid (some rusting on inside lip)
Two original doors (some rusting on bottoms)
Bonnet (some surface rust)
Rally Chassis reinforcement kit
RS type suspension reinforcement kit
Original scuttle panel
Petrol tank with cap
Misc. items included:
Wiring loom
Front and rear lights and indicators (one front indicator has a smashed glass)
2 dial instrument cluster
Dash switch panel
Rear screen and rear quarter glasses
Door rubbers
Steering column and wheel
Pedal box
Number plates
Sun visors and other misc interior trim
Wiper motor and mechanism
Washer bottle
Bump stops and steering cowl
Work carried out:
Rear bubble arches welded onto body
Front bubble arches welded to new front wings
New strut tops with AVO strut reinforcement fitted
Group 4 rear turrets fitted
New rear panel fitted
Fuel tank repair well
New splash shields fitted to both sides
O/S door hinge panel fitted
Pictures can be found at www.flickr.com/photos/127197659@N07
If any more pictures are required please ask, viewing is highly advised. The shell is also advertised elsewhere so could be removed any time.
Price is £2,500 please contact Ian on 07741699541 at any time for more info and viewing.
Thanks for looking
New front panel
Two new seat rails
New heater bowl
Wiring loom
Dash switch panel
Door rubbers
Pedal box
Number plates
Washer bottle
Work carried out:
Thanks for looking
