I bought this last year but it had a few faults the seller forgot to mention, so I left it and bought a new car, since feb I have spent a small fortune on it and it has been used as a third car. Circumstances mean it now has to go though,
it is moted for 12 months requiring some sill welding although the rest of the body work is very good
it has recently had new plugs, leads cap and rotor arm, new throttle position sensor, anti freeze flushed and changed, new battery, new discs and pads all round, new boot struts,drive belts replaced,new rear calipers, new rear shock absorbers, new rear exhaust box, auto gear box replaced with one from a low mileage car with new gaskets and filter, just had oil change this week
Interior in good condition apart from 2 cracks on the dash, all the electric seats windows and sunroof work. The air con doesn't work, the fan spins and the compressor turns freely but it wont activate as the is no gas in the system
minus points,
bit tappety when cold
brake warning light flashes when you start up as the replacement pads didn't have sensors, there are rear pads included or just short the wires on the warning system
one of the front pipes has a slight blow, there is a new pipe to go with the car
I am putting it on here with the hope of it going to a good home rather than a idiot off ebay,
may take part ex escort, orion triumph acclaim or something smaller
minus points,
