May 20, 2007 23:23:21 GMT
told my mother i'd fix her micra tomorrow - the indicators and the hazard lights have stopped working.
i thought - easy peasy, deffo a fuse, leave it here and i'll fix it.
swapped the relevant fuse - nowt. checked connection to switch - nowt wrong. so i reckon its the relay.
anyone know where to find it on "02" plate micra???
apologies for the most boring question ever but i wont have much time tomorrow, one shot at the scrappy and the local library aint got the haynes manual in.
any help appreciated, most abuse tolerated
if this van's a rocking... then my starter motor is probably fecked again
goddamn modern carsmilfordcubicle
@GUEST
The relays are sometimes in a panel under the steering wheel or in the engine bay - often they're mentioned in the handbook.
Last Edit: May 21, 2007 0:11:53 GMT by milfordcubicle
RetroMat
Column Shifting!
madmart
love is: valvebounce in top gear
try also playing with the hazzard switch, sometimes the indicators are wired through it and they get bad connections sometimes the indicators will work with the hazzard switch held in etc
