Oct 24, 2014 20:58:02 GMT
Could anyone shed some light on this one? I have a B2 83 carbed auto 1600 with a WV code engine in it. I need to replace the pipe from the back of the head to the auto choke on the carb. The number I have come up with is 026121058C from: www.partscats.info/audi/en/?i...parent_id=1284I think this is correct however nothing comes up on google or ebay and my local source (wvs) in Bristol has tried ordering it from VVW. It is now on backorder with no delivery date. VWS parts bloke thinks this is the same as saying **** off I have tried buying pipe from the reel my local autoparts. It was then I clicked that one end is 13mm(carb) and the other is 16mm (pipe on back of head). Any help appreciated.... Have a pic of for your time... wish I still had that one
Oct 24, 2014 21:25:46 GMT
How about making it in copper with Yorkshire fittings, 15mm and 12mm reducer/bends as necessary, the raised rings will allow you to use rubber pipe and get a good seal. Paint it black once done if you need to discuise it.
Brian
Oct 24, 2014 21:51:34 GMT
Oct 24, 2014 22:25:30 GMT
thanks gents.
Would like to keep it original if I can. Its only done 50K from new. I have focussed on just the pipe and have not even considered 'outside' the box.....
What about getting one made up at a silicone hose place?
- '88 MK2 Golf 1.3 c - '07 BMW E91 335d - '94 T4 1.9d
Oct 25, 2014 12:20:26 GMT
I'm assuming you've tried gsf and ecp? They're usually pretty good at getting parts in that aren't on the shelf
Oct 25, 2014 12:22:39 GMT
Use original. I had a 82 Passat 1600 and same hose burst. New VW part expensive so I found a new Ford hose that was the right shape so fitted that only for it to split within days. As an emergency AA fitted a length of plain hose to get me home and again it burst after a few miles. Both time it was due, I reckon, to the difference in end dia. Next day bit the bullet and forked out for a genuine hose and never had any more problems.
Oct 25, 2014 18:11:07 GMT
I'm assuming you've tried gsf and ecp? They're usually pretty good at getting parts in that aren't on the shelf must be my age but I get nothing but attitude from our local ecp. gsf on hte last few occasions I have phoned for audi parts have been helpfull but we no longer stock etc... Try both Monday
Oct 25, 2014 18:14:15 GMT
I'm assuming you've tried gsf and ecp? They're usually pretty good at getting parts in that aren't on the shelf must be my age but I get nothing but attitude from our local ecp. gsf on hte last few occasions I have phoned for audi parts have been helpfull but we no longer stock etc... Try both Monday interesting story give me some hope for the head gasket still being in on peice. Can you remember the part number? or is it the same as I have quoted?
Oct 26, 2014 18:05:06 GMT
Oct 26, 2014 22:53:42 GMT
Thank you mr dasterdly. I shall send them a missive...
I tried them for the std part. So far I have just been referred by tham to AUDI customer services in Sheffield. I will email them next week. I have bought some samco hoses this morning and will fit them today.
All fitted now. YIIPPPEEEEE.
hang on whats that......
Leak on the heater to head hose now.
OLD cars :-)
Ah well, at least you got one thing sorted!
