Oct 29, 2014 22:23:11 GMT
Hi all,
Some of you may have seen my build thread on here where I'm rebuilding my Davrian (among other projects).
What i need help with is the brakes. I have decided to use polo 9n alloy calipers on the rear, but I'm struggling to find something suitable for the front. I need them to fit inside a 13" wheel, i don't mind really if they are for vented discs or not, my main criteria is that they be alloy and not steel to try and keep the unsprung weight down.
So far i can only find some from some models of Peugeot 106, but these seem to have odd sliders? and possibly some that come off of a VW Lupo 1.2tdi? but i cant find much concrete info on them?!
Does anyone have any ideas/info/pics that might help me out?
Thanks in advance.
Oct 29, 2014 23:04:21 GMT
whats odd about the bendix sliding caliper?
found on most 205's in non vented, but vented on the 1.6 gti, same caliper found on the series 1 106's.
Oct 29, 2014 23:10:01 GMT
How about some aftermarket 4 pot calipers for a Mini?
Click picture for more
Oct 29, 2014 23:12:13 GMT
I couldnt find any good pictures of them, or the caliper bracket, but the sliders don't seem to be symetrical either side of the piston? would like to see the bracket to see the bolt holes to the upright.
What size disc are they for?
ettorebugatti, originally i was going to fit a cast iron set of the mini 4 pot calipers but decided that they were far too heavy, and to be honest i think the 4 pots will be overkill on a sub 600kg car. Plus ideally I'm looking for something at the cheaper end of the scale. Appreciate the suggestion though.
Cheers
Oct 30, 2014 11:25:30 GMT
Pug 306 td calipers are about the bigest you can get that fit under 13s. I had them on my 205 rallye and they were damn good.
They have a much larger piston than the 205 version.
Last Edit: Oct 30, 2014 16:35:35 GMT by joem83
Oct 30, 2014 12:09:30 GMT
Skoda Estelle, Mini Metro should give ample breaking on the front be pretty cheap. I've just last weekend thrown out some brand new Skoda estelle callipers as I was bored of tripping over them and after many failed ebay sales I'd had enough.
Some days you just need to take a grinder to an inanimate object, just to make your day a tiny bit better!!
Oct 30, 2014 16:31:27 GMT
I'd go with an aftermarket light 4 pot too, you'll get all the stopping power you need from them, run a Bias valve to sort the balance out and a suitably large master cylinder. Is the car servo assisted?
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
Oct 30, 2014 19:43:47 GMT
wilwood 4 pots for 13s are actually pretty cheap these days. sure i saw them for a shade over 200 quid somewhere recently.
Oct 30, 2014 19:54:13 GMT
Wilwood powerlite. radial mount,,two sizes, for vented or solid discs. designed to fit under 13 inch wheels. £95 each plus vat (Demon Tweaks) pads are about £50 iv'e got some for the S800
Last Edit: Oct 30, 2014 19:57:38 GMT by Bozwell
Got those alloy 4pot calipers (vented) on my old mini, under 10 inch rims. Engine puts out 150bhp and weighs about 650kgs. Superb braking....stops on the proverbial 6pence.....
omega
Pug 306 td calipers are about the bigest you can get that fit under 13s. I had them on my 205 rallye and they were damn good. They have a much larger piston than the 205 version. but can you get any decent pad for these?
Last Edit: Nov 1, 2014 18:26:27 GMT by joem83
what about the standard girling calipers you get on spittys/heralds? think they use them on caterhams too. they'll fit under a 13" wheel easily, nice selection of disks and pads from road to full race and you can pick up a set for next to nothing.
Last Edit: Nov 7, 2014 16:36:30 GMT by yorkebar
Nov 12, 2014 19:19:03 GMT
I used some fiat panda calipers on the back of my 410 a few years ago and from memory they were alloy and very light. They were certainly easy to adapt and worked well.
Nov 13, 2014 12:46:39 GMT
Why not use bike calipers???
Nov 13, 2014 12:56:24 GMT
I use Fiat X1/9 calipers on the front of my racing Clan The're alloy and more than up to the job with decent pads. Also use the Fiat discs and have had no problem with them. Worth checking on calipers from the Fiat small car range. I've found no need to but if you wanted to you could use the calipers and vented discs from the Uno Turbo.
Pete Richards
Nov 13, 2014 15:46:03 GMT
Citroen visa calipers. Twin pot and alloy
muttley racing ftmfwmf
