Hi,
after troubleshooting problems with running, and then starting, I found that the composite base under the fuel (petrol) pump seems to be at fault. All the ridges outside where the two O-rings sit had broken away. Tried to show this by circling affected areas in red;
Is this a common problem?
Am I right thinking that the bits have broken off due to over-tightening the nuts that hold the fuel pump in place?
Ta
Ta
