Nov 28, 2014 12:01:16 GMT
Still not sorted guys Changed the ball joint tre's and tie bar bushes had it tracked up- still vibrates through the ateering wheel anything above 60mph. I hate the thing just want it repaired so i can sell it. The only thing left is the driveshafts i had my mechanic give it a check and he says the long driveshaft could be the suspect as its a speed related vibration. Going to source one and fit it wont hold my breath. What a shame.
BLU
Nov 28, 2014 17:04:46 GMT
Still not sorted guys Changed the ball joint tre's and tie bar bushes had it tracked up- still vibrates through the ateering wheel anything above 60mph. I hate the thing just want it repaired so i can sell it. The only thing left is the driveshafts i had my mechanic give it a check and he says the long driveshaft could be the suspect as its a speed related vibration. Going to source one and fit it wont hold my breath. What a shame. Is the weight still on the shaft? Big thing in the middle of the shaft........ there will be a mark where it was if its missing!
Last Edit: Nov 28, 2014 17:05:51 GMT by BLU
The future's bright, the future's BLU
Silver 1987 MK2 Fiesta Ghia White 2006 MK6 Fiesta ST150 Yellow 2007 MK6 Fiesta Zetec S Anniversary #279 Green 2007 MK6 Fiesta Zetec S Celebration #471 (diesel conversion) Red 2008 MK6 Fiesta Zetec S Anniversary #893
Nov 28, 2014 17:11:51 GMT
Still not sorted guys Changed the ball joint tre's and tie bar bushes had it tracked up- still vibrates through the ateering wheel anything above 60mph. I hate the thing just want it repaired so i can sell it. The only thing left is the driveshafts i had my mechanic give it a check and he says the long driveshaft could be the suspect as its a speed related vibration. Going to source one and fit it wont hold my breath. What a shame. Is the weight still on the shaft? Big thing in the middle of the shaft........ there will be a mark where it was if its missing! Yep the weight is still there and is untampered with mate its completely making me go mad this vibration wish just wish i could pin point it but *visually* nothing looks fubbard but thats half the fun
Nov 28, 2014 20:03:09 GMT
As a experiment swap the front and rear wheels around see if it makes a difference. When I first got mine it was fine and then I started getting bearing noises where the tyres has distorted
BLU
Nov 29, 2014 16:48:34 GMT
What wheels are on it???
