furb
thnx the grey one is just for reference, not mine.. but that guy has helped me make some decisions on what parts to use. my RX-7 has been a 8 year learning process, and from that i also learned what NOT to do. that's why i have taken more care in planning and building this new project. that's partly why i do it, i love the feeling of that moment when you turn the ignition and the engine comes to life, knowing i built that
infamous
www.motacarblog.com
Nov 20, 2014 11:47:10 GMT
Well this is awesome!
Nov 20, 2014 17:46:51 GMT
Wow. Love the details! I like the gauges. Which g box is that? If it has the same take off thread as a series 1,2,3 box then you can use a electronic speedo pick up from a 90's toyota celica. They screw straight on perfectly and there you have a simple way to get your pulse for your gauge. But you've sorted that now:-)
furb
Nov 20, 2014 21:17:22 GMT
thats a S4 TII transmission, have bought that one brand new a few years back for my FC
luckyseven
Club RR Member Number: 45
Nov 20, 2014 21:39:15 GMT
Been paying closer attention to the photos; I see OMP lines and injectors but how will you supply them? Using the original OMP or a remote pump with separate oil reservoir? Always interested to hear solutions to this one; I'm currently premixing on my FB and using the stepper OMP on the FD but I'm not sure I'm happy with either method 100%
furb
Been paying closer attention to the photos; I see OMP lines and injectors but how will you supply them? Using the original OMP or a remote pump with separate oil reservoir? Always interested to hear solutions to this one; I'm currently premixing on my FB and using the stepper OMP on the FD but I'm not sure I'm happy with either method 100% I built my own OMP adapter to fit a S4 OMP onto the 12A front cover and to block off the standard oil passage and indeed run a separate tank with 2-stroke oil. 2 of the lines go onto the oil injectors on the housings, the other 2 will go onto the float bowls of the carb, so it's almost like premixing I absolutely hate premixing...! I don't want the hassle at the gas station, figuring out how much oil I need to put in before I fill up. My tank is 1,5 liter in capacity, so I just dump in an entire bottle in one go, no hassle in that The S4 OMP is mechanically linked to the throttle, so it always works
luckyseven
Nov 21, 2014 15:01:00 GMT
Yeah, it sounds like the best of both worlds. I was thinking about one of the Rotary Aviation OMP separator plates, but then my fabrication skills rather below yours, lol. Not brave enough to try making my own!
furb
Nov 21, 2014 16:24:16 GMT
I had one from them on my FC, but that one didn't fit anymore with this setup I had a good example of how it should work so built a new one
Nov 23, 2014 14:02:32 GMT
awesome job so far, always love a good RX2/3/4
furb
Nov 23, 2014 20:23:27 GMT
furb
Nov 25, 2014 14:54:40 GMT
fitted an oil supply to the float bowls so that i get a bit of premix next to the housing injectors for better lubrication of the apex-seals. its also adjustable so i can prevent saturation of the float bowls made a bracket for the throttle and choke cables
furb
haza1024
idiot proof until someone invents a better idiot
Bookmarked
You're a lucky guy i have always wanted an RX4 if i could get my hands on a shell no one would ever see me util that thing was done.
really clever work with the intake flanges and carbs good effort, I'm looking at putting a weber downdraught on my rx4 lump in the viva but finacially its proving tricky.
do you know anything about the old hitatchi carbs as thats what i have and its being a pig to get right!
moomin
Beauty in the making!
@toxicknobs
furb
Bookmarked You're a lucky guy i have always wanted an RX4 if i could get my hands on a shell no one would ever see me util that thing was done. really clever work with the intake flanges and carbs good effort, I'm looking at putting a weber downdraught on my rx4 lump in the viva but finacially its proving tricky. do you know anything about the old hitatchi carbs as thats what i have and its being a pig to get right! thnx i am also spending a lot of time in the garage, and now the shell isn't even there.. when it gets back from paint i will take it up a notch and get cracking, want this thing on the road! i have never even seen a hitachi carb.. these are also my first carbs i've ever worked with, so i will probably get some headaches too before its done
Last Edit: Dec 7, 2014 20:20:06 GMT by furb
furb
Massive leap forward there, but the paint looks great!
Now having images of a white RX-4 with a brilliant red leather interior. Would look amazing, but so will red on red.
Dec 13, 2014 17:15:07 GMT
looks a great red
furb
Jan 12, 2015 20:13:35 GMT
