Sinky
Run Baby Run......Please!
Nov 17, 2014 18:44:59 GMT
Hello.Can you help?
My son has just fitted a new slave cylinder to his Civic. Easy enough job. But we are trying to bleed and cant get any fluid coming out the bleed nipple. Clutch seems fine and good pressure? Have we done something wrong? Should there be fluid from the nipple?
Thanks in advance Sinky
2001 Volvo XC70 wagon
2003 Piaggio X9 Evo
rodney
Nov 17, 2014 20:16:40 GMT
is it topped up with enough fluid?, if I can get em to bleed the normal way I let em self bleed with the nipple open for a while ,
why was the slave replaced? because the master could be at fault,.
Sinky
Nov 17, 2014 22:12:45 GMT
Ymax on fluid. The slave was replaced because it was leaking. The master looks ok.
2003 Piaggio X9 Evo
Hi, from experience I would do the master as well, in the past if one has failed the other has failed shortly after. One thing you could try is to connect an oil can, with brake fluid in, to the bleed nipple and pump fluid back up into the master which should take the air up with it.
Colin
Sinky
Thanks for advice guys. Do you reckon its a air lock then?
2003 Piaggio X9 Evo
ben-dover
You can't polish a turd, but you can roll it in glitter...
Nov 18, 2014 18:48:55 GMT
1: Check replaced part, I have had after market parts that have had no holes drilled for bleed nipple or feed pipe! (Euro's anyone???) 2: Schoolboy error's, is the pipe clamp still on or feed hose twisted, bleeding correctly? (no offence meant by these comments!) 3: Seals in master cylinder turned due to ridges in cylinder wall stopping fluid flow? (usually happens to brake masters due to sudden excessive travel when bleeding) 4: curse word in reservoir blocking feed? 5: Air lock, try to suck fluid through using clear pipe fixed on the bleed nipple (be careful not to get a mouthful!) 6: Bleed as normal but when lifting pedal (nipple closed) go very slowly, some cylinders are very slow to re-fill. 7: Finally, shut nipple, pump the hell out of pedal until some resistance is felt, prop pedal down with something, leave overnight, try again in the morning. This can encourage the air to travel to the reservoir.
Other then that I'm out of ideas!
Sinky
Nov 18, 2014 22:53:17 GMT
Cheers Retro77 Very helpful
2003 Piaggio X9 Evo
ben-dover
Nov 19, 2014 19:51:50 GMT
No worries, let me know how you get on
