Stoke8v8
Megasquirt M117
Dec 24, 2014 15:37:28 GMT
a couple of months away yet -- typically nice enough in March or April to get the car out of here and on to the road.
hopefully nothing is horribly wrong once we get it rolling under its own power.
76' 240D M117 91' M3 S54 88' M3 S54 87' 325i M54 ZHP 91' 850/6 04' Vespa 200GT 89' 325i coupe eBay turbo project
Dec 24, 2014 17:28:13 GMT
the 500SEL diff is supposed to be a direct bolt in and offer the larger ring and pinion. so I'm told. Yeah I heard the same thing, but when I compared the two diffs underneath the car I couldn't see any way that the W126 diff would fit the W115 subframe. The W126 diff is huge compared to the W115 one. I think there's a difference between early and late W126 diffs, so perhaps that's where I'm going wrong and I have the later 500SEL diff or something.
Last Edit: Dec 24, 2014 17:29:00 GMT by BenzBoy
Dec 24, 2014 17:35:57 GMT
the 500SEL diff is supposed to be a direct bolt in and offer the larger ring and pinion. so I'm told. Yeah I heard the same thing, but when I compared the two diffs underneath the car I couldn't see any way that the W126 diff would fit the W115 subframe. The W126 diff is huge compared to the W115 one. I think there's a difference between early and late W126 diffs, so perhaps that's where I'm going wrong and I have the later 500SEL diff or something. correct. the changeover is 1985 iirc. the early ones are the same as w116, the later ones are much bigger.
berendd
why do I need 3 keys for one car?
Dec 24, 2014 20:53:30 GMT
Stoke8v8
Megasquirt M117
correct, it has to be an early 85 euro 500 SEL or SE from what I gather.
either way, not worried. the ring an pinion in the 240D rear end is 7.6" or larger as it is, and that should have zero issue shuffling around 350lb/ft tq in a 3100lb car
Stoke8v8
Megasquirt M117
no progress today due to holiday vacation. stay tuned.
Dec 30, 2014 13:02:48 GMT
Nice work. But what was wrong with the original oil pressure gauge? I liked it better.
Stoke8v8
Megasquirt M117
Dec 30, 2014 15:20:27 GMT
it was a mechanical gauge. the M117E55 does not have any privision for a mechanical gauge.
Stoke8v8
Megasquirt M117
lots of boring and hard to photograph progress today * Electronic oil pressure gauge works now * Gas pedal is solidly mounted now, although still only getting 0-20% throttle sweep on the main throttle body. * test fitted some 1992 190E 2.6 radiator fans I had laying around and they're a spot on fit. may still end up going with the original /8 Fan though * re installed main engine mount nuts exhaust shop removed * welded in a stronger mount for the brake booster * re attached and verified function of hood latch and release. * ordered many parts * installed new turn signal stalk that self- cancels properly * new radiator cap, hoses felt a little hard for my taste. patiently waiting for spring time now to test drive and debug.
Stoke8v8
Megasquirt M117
Jan 11, 2015 19:20:36 GMT
Stoke8v8
Megasquirt M117
new switch plate for rad fan and fogs vintage Philips fogs installed
mhuk
Jan 26, 2015 11:46:27 GMT
I love it. I have thoughts about getting a old merc and sticking a later diesel lump in (w210) and running veg oil.
Spitfire with a mx5 turbo engine
Merc W210 on veg oil running water injection.
Stoke8v8
Megasquirt M117
Jan 26, 2015 15:54:36 GMT
we were on the fence between this and an OM606 honestly.
Stoke8v8
Megasquirt M117
🇿🇼Kingludba🇬🇧
If in doubt... flat out !
good stuff! getting there dude
`99 BMW 528i auto - current `01 Merc C320 - Gone `01 Forester S-Turbo - Sold `89 BMW 320i Convertible - Sold(shoulda kept it ) `88 Toyota MR2 T-Bar - Sold `89 BMW 325i touring - Sold `89 BMW 535i - Let her go too early `85 BMW 320i 2 door - Rust = character `00 Subaru Impreza Turbo wagon - Sold (engine failure) `93 BMW 325i - Sold
Stoke8v8
Megasquirt M117
painted and reinstalled the switch bezel purchased factory door switches and swapped them out. originals were quite corroded and did not function reliably. found out the trunk dome light assembly still worked, just needed a bulb! reinstalled center console for the first time in 5.5 years. she's getting so close
Stoke8v8
Megasquirt M117
a little mid-week surprise for all you Ronal wheel haters! CLK/C classe 16x7 forged lightweight alloys for the /8. excited to start refinishing them and getting some proper new rubber on them before springtime.
🇿🇼Kingludba🇬🇧
What are your plans for the interior...front seats? Are you staying retro or upgrading to later model ones with better support?
Stoke8v8
Megasquirt M117
re stuffing the front seats as all of the horsehair is gone, but keeping it original. Always loved the interior on this thing. so much more modern than most 40 year old vehicles.
Stoke8v8
Megasquirt M117
Feb 19, 2015 19:17:58 GMT
