Here is my trophy winning 1988 early spec jetta,its won sponsors choice award at edition38, carpark hero at show and glow and best mk2 at Bristol volksfest
Engine
It started as a 1.6 petrol but has been converted to a 1.6td which is amazing on fuel reaches up 50 mpg on a run easily, perfect for going about the country/Europe for shows while the engine was out it has been fully serviced, has been wired up on a proper glow plug relay so the plugs heat at the first turn on the ignition as it would be from factory , engine was painted high temp satin black with gloss black rocker cover, the donor engine has covered 140k, has a full 2” stainless steel exhaust with custom tail pipe
Exterior
Its had full strip down and respray in vw lido green including engine bay, door shuts inside the panels ect, there was very minimal welding to be done on the car but any that had to be done was done properly by being cut out and replaced with fresh metal then sealed ect, all of the arches have been fully rolled flat and sealed, has also had a full pre 88 early spec conversion including doors replaced with the early quarter glass window models, 7 slat grill, lhd wipers, arch spats and all the other relevant trim to match the earlier models, also a early jetta gtd rear badge and gtd side repeater blanks which were not available on uk cars
Interior
Brown tweed seats front and rear, cream door cards, brown carpet, early cl centre console, brown A and B pillar trims wooden nardi wheel, wooden gear knob also have a brown dash that I was intending on fitting so can go with the car
suspension
Its running jom coilovers which are in good condition no leaks and adjusters have been copper greased so move freely they also give a relatively comfy ride !
Wheels
its currently sat on steels , can include a set of Schmidt modern line 15x8 et25 wrapped in nankang ns2, BBS SOLD
£3500 on steels or £3800 on schmidts , open to PX/swaps
Contact via pm or 07766384178 located in taunton somerset
i832.photobucket.com/albums/zz248/harryshotta2103/Mobile%20Uploads/image_zps37c604c2.jpg[/IMG][/URL]
Engine
Exterior
Interior
suspension
Wheels
