ckerr
Nov 26, 2014 11:18:12 GMT
Things used to hold bonnets open..
What all have you seen used to hold open, partly open / closed bonnets at car shows? Lanyards? Fancy Chain? What else?
I have a beetle and fancy making under the bonnet a bit of a show piece for no reason really, just a bit of fun, the bonnet is sprung so when you open it, it’s open right up the air… Though about modifying a baseball bat to hold it partly open / closed or a vintage ski pole…
Anyone any photos of stuff they have seen at shows?
Nov 26, 2014 11:29:19 GMT
I like to use the little metal arm that came attached to the car designed for keeping the bonnet up. It's adjustable in two positions and you don't need to remember to take it with you.
Iain
Nov 26, 2014 11:57:02 GMT
Bonnet propped open by camshaft looked quite cool.
Don't get leaving a beer/cider can under there, might as well shut it.
Nov 26, 2014 12:16:51 GMT
I used a ratchet strap on my Land Rover. If you unhook the support then it will open further and rest against the roof. It only took it being blown onto me once, whilst working on the engine, to realise that it needed some sort of secure support. With that in mind be careful about simply propping it open with baseball bat, camshaft or whatever as all it'd take is somebody to knock the car or gust of wind to dislodge the support and bonnet to come crashing down. If you want to make it "trick" what about a linear actuator to make it remote power open and close ?
Nov 26, 2014 12:29:00 GMT
always aware when i open the bonnet to 90° on the Mercedes as the only support seems to be the hinges but i havent heard of one going to far over, but if you open it normally as with most people who have owned a mercedes will confirm you end up smacking your head sooner or later! also trying to open the bonnet up to 90° on your own can at best be difficult
vulgalour
Club RR Member Number: 146
Nov 26, 2014 12:42:21 GMT
Best way to keep it open a set amount when it's a sprung bonnet is to tie something between the two parts of the latch. A period gents tie like the above would be very suitable for this purpose, easily obtainable in a wide variety of colours and patterns. There's loads of things you can use in the same vain, all depends what sort of look you're going for with the end result.
Nov 26, 2014 13:14:30 GMT
For a sprung open bonnet then a small retractable dog lead (they lock at any length)could be modify to work.
VIP
Nov 26, 2014 13:45:44 GMT
Surely the point of holding open a bonnet halfway to 'look cool' (questionable in itself) is to use something interesting to do it, not something you scrabbled around in the boot to find as a 'make do', like a tie or dog lead would?
ckerr
Nov 26, 2014 13:47:06 GMT
Some cool ideas, Just thought some seat belt webbing. could use the latch at the end of make a hook.
Nov 26, 2014 14:40:56 GMT
I removed the spring an old beetle of mine and couldn't refit it! I used on old cut down golf club as a prop
ckerr
Nov 26, 2014 15:37:01 GMT
What was it?
... Never mind see it now. Image didnt load
Last Edit: Nov 26, 2014 15:38:03 GMT by ckerr
Nov 26, 2014 16:17:33 GMT
Nov 26, 2014 16:53:38 GMT
Please don't throw litter, take it home.
Davenger
It's only metal
Club RR Member Number: 140
Dec 12, 2014 22:31:33 GMT
This is how I was rolling at RRG14
