106e30
Dec 15, 2014 15:20:22 GMT
This morning on the way to work my indicators started to speed up when turning left, so naturally I thought a bulb had blown.
I always carry a spare one so I tried to change it on my lunch break. I put the new bulb in and tested it. The bulb didn't light up and there was a buzzing sound coming from the left hand side, It sounds like the buzzer you would press to get into a block of flats. So I'm left with no indicators at all on the left side and a huge buzzing sound .
Any ideas..I have a lot of left turns on my way home!!
Last Edit: Dec 15, 2014 15:20:59 GMT by 106e30
Own 1991 BMW E30 318is Owned 2002 Peugeot 106 1.1 1979 BMW E12 520/6
shin2chin
Dec 15, 2014 17:39:51 GMT
Faulty indicator relay in the fusebox?
Dec 15, 2014 19:29:04 GMT
If its a lateish vauxhall it will be the relay thats failed. It can do all sorts of wierd and wonderful things
106e30
Dec 15, 2014 19:55:01 GMT
It's a BMW e30.
Investigated it further when I got home. It looks to me that as I've pulled the bulb out, one of the connectors has come loose and so when I put the new bulb back into place, it is pushing the two connectors together and shorting the circuit. Going to take the unit out tomorrow and see if I can fix it, other wise It's getting replaced.
106e30
Dec 15, 2014 19:55:24 GMT
oh and thanks for the suggestions
Dec 17, 2014 13:33:52 GMT
Deffo sounds like the relay has gone.
106e30
Dec 17, 2014 18:44:03 GMT
All done and dusted, had to take the bumper off and replace the indicator units. what should have just been changing a bulb somehow turned into an hour and a half with the car on axel stands and no front bumper.
Thanks to you guys for trying to help
