tim124
Dec 17, 2014 17:41:37 GMT
72, Cortina estate, with Pug TD engine, the temp gauge is not reading any thing, the gauge is good. Could some one please measure the resistance of the Ford Pinto temp' sender please? Thanks, found this on the net......... '' Testing the coolant temperature sensor is a very quick process. With the use of a digital volt ohm meter you can easily tell if the sensor is faulty or not. Connect the black lead of the digital ohm meter to a solid ground. This can be any solid piece of metal. Next, connect the red lead to the terminal end of the coolant temperature sensor. '' Read more: www.doityourself.com/stry/how-to-test-a-coolant-temperature-sensor#ixzz3MB68OeKD
bortaf
Dec 17, 2014 18:15:54 GMT
There's 3 or 4 differant ones, your's being a cortina it will be the white ring sender you need the readings from (the differant colours are differant resistances). I have an intermotor cat here but it doesn't say the resistance range i also have the correct white sender here but no test meters till i get to work tomorrow but you really need to test them cold and up to temp whilst in the car to get the correct range, at cold all will be virtually the same resistance. EDIT: Nothing in the factory cortina manual either, seems sender resistance is uber secret or sumink, even the intermotor catalog shows everthing appart from temp sender ranges, shows oil pressure switch ranges, rad fan on and off ranges but buggerall for temp senders
Last Edit: Dec 17, 2014 18:33:46 GMT by bortaf
R.I.P photobucket
tim124
Dec 17, 2014 18:31:29 GMT
Thanks for that, perhaps some one could read a sender unit,whilst the car is up to temp?
bortaf
Dec 17, 2014 18:41:36 GMT
I have to fit a new (black) sender into my P100 anyway this week, i'll swap the white one in first and see what that reads and let you know i know the white one reads lower than the black one on the gauge cos i took the white (wrong) one out and fitted the black (correct) one last year. Might not be till friday though i have a clio engine to fit and get running first, should be simple but something will go wrong lol if i get a chance i'll get it in tomorrow but can't promise
R.I.P photobucket
tim124
Dec 17, 2014 21:20:34 GMT
Bortaf, Your a star thanks for your help, but no need to rush about with this, it'll keep till you have the time...... Cheers buddy....
Dec 18, 2014 18:22:41 GMT
Have a look on ebay, there are a few different ones and when i got mine the scales were listed.
bortaf
Sorry not had the chance to get it in yet, bloody clio owners and thier halfassed attemps at DIYing It will be in tomorrow mate i want at least 1 gauge working on the truck
R.I.P photobucket
bortaf
Dec 21, 2014 23:31:09 GMT
Fitted the temp sender today, 5 mins later it stopped working fooking cheap chinease cr@p ! taking it back tomorrow
R.I.P photobucket
bortaf
Dec 22, 2014 17:19:25 GMT
Fitted 2nd new sender Lasted 2 mins before nowt 3rd new sender, no worky at all tried analog and digital Fook all I'm gonna bite the bullit and go to Fords in the morning and see if they have one sorry mate this is aint helping is it, anyone got a sender that actually works ? bloody intermotor cheap cr@p
R.I.P photobucket
Dec 22, 2014 18:25:38 GMT
I think when I checked mine it had between 60 and 80 ohm at running temperature, BUT i've no idea if this is correct as god alone knows what sender is fitted and my temperature gauges don't work..
tim124
Dec 22, 2014 19:44:30 GMT
Sorry to see your having so much trouble!, thanks for the effort.......
bortaf
Dec 23, 2014 13:35:27 GMT
It's no trouble mate i need to get the temp gaige working anyway, just my luck to get all fooked senders i'll see what Ford can do for me ?
R.I.P photobucket
