slomoshun
Going forward one nut and bolt at a time
Dec 30, 2014 21:03:26 GMT
Have a 1998 Rover 820 badged 800 and want to fit a sport dished leather rim steering wheel. Cannot source a wheel boss kit for that model but got me wondering if any other Rover or otherwise use the same steering column and have same spline compatibility. Long shot but so much tech information from forum members might throw up an alternative ? Thanks
Traction and horsepower is nearing perfection
820
Dec 30, 2014 21:10:39 GMT
slomoshun
Dec 30, 2014 21:50:14 GMT
if that boss kit will fit my 1998 820 ill be very happy horn i would reroute to a push button switch , rewire throughout to newer type klaxon horn and srs light id bypass with a resistor that appears to solve the problem from what ive read all after next mot i might add but thanks for pointing me in right direction
820
Dec 31, 2014 18:45:38 GMT
Yes that boss kit is for the 800, just use the drop down menu to select
slomoshun
Dec 31, 2014 21:33:40 GMT
drop down menu says 1991 onwards so assume same fitting onwards to mine a 98 model never seen a modified 800 or 820 forums ive visited seem full of must be standard anoraks cos when i mentioned modifying the reply was stuffy and full of amazement. Maybe the 800 forums are really not for me and my wayward thinking but a modded 800 will be rare i suppose
squonk
That is probably because removing the original steering wheel complete with air bag constitutes a major modification in the eyes of an insurance company as you have compromised a major safety system on the car. If you don't inform them it is guaranteed that they will not pay out in the case of a crash that causes personal injury (or possibly any crash for that matter). If you do inform them I suspect you will be in line for rather a large hike in premium as one of the largest expenses for an insurer is a personal injury claim and increasing the likelyhood of an injury being sustained in an accident is significantly increasing the insurance risk. Bring back the good old days when you could just buy a steering wheel at a custom car show and fit it without fear of reprecussions!!
Last Edit: Jan 4, 2015 10:12:09 GMT by squonk
slomoshun
Well put that way it don't sound such a viable idea but your right good old pre air bag days things were more simple
Club RR Member Number: 160
Rover Steering CompatibilityRich
@foxmcintyre
Club Retro Rides Member 160
And You are going on the assumption that the SRS system in a car that old would actually deploy.. The manufacturer recommends pyrotechnics replacement every 8-14 years. I can promise that has never been done..
squonk
And You are going on the assumption that the SRS system in a car that old would actually deploy.. The manufacturer recommends pyrotechnics replacement every 8-14 years. I can promise that has never been done.. Do you honestly think that an insurance company would take that into account if they felt they could otherwise get out of a claim? Quite simply its not worth the risk.
@foxmcintyre
And You are going on the assumption that the SRS system in a car that old would actually deploy.. The manufacturer recommends pyrotechnics replacement every 8-14 years. I can promise that has never been done.. Do you honestly think that an insurance company would take that into account if they felt they could otherwise get out of a claim? Quite simply its not worth the risk. Best thing to do is talk to your insurance company first. I wouldn't personally trust a 15 year old airbag more than I would a a good quality steering wheel boss collapsing and a seat belt. But yea, that isn't really a deal for insurance to worry about.
slomoshun
Jan 24, 2015 16:33:14 GMT
820 How did you get on with srs light ? Did you get that boss kiy / What year is your Rover out of interest ? Still considering that boss kit after the mot
slomoshun
Jan 26, 2015 17:22:39 GMT
checked on the boss kit it is to order £ 39 plus vat reckon should be able to bypass air bag via a resistor
820
Jan 26, 2015 21:52:31 GMT
I now have everything I need to do a diagnosis and reset on my 20 year old SRS system, so plan at the moment is to stick with the Rover steering wheel and fix the SRS so I can get it MOT'd
slomoshun
Jan 27, 2015 19:35:25 GMT
just put a deposit on the boss kit but wont be fitting till after the mot in may then if still got the 820 fit it back on for another mot then change back / crazy yeah but thats the retro life
@foxmcintyre
Jan 27, 2015 22:00:11 GMT
You don't need to refit the air bag for the mot. It is only tested if present, if it is removed and the lamp isn't on, it's a pass. Why anyone would go through the hassle of swapping each year defeats me..
slomoshun
Jan 28, 2015 11:26:08 GMT
thanks for info
slomoshun
Jan 30, 2015 15:35:35 GMT
what size is the centre nut holding steering wheel on a rover 800 /820 handy to know before i take air bag off thanks
