I was given this pump a few years ago from a friend, I have quickly wired it up to do a a dry run to see if the pump fires up which it does.
Has anyone got one or used one?
I want to know does it have to sit vertically or can it lay horizontally underneath the car with the fuel tank?
what threads are on the pump?
I am going to be using bike carbs which run at 4 PSI (looking ata filter king/ regulator) so is the pump to big to drop down to that pressure?
And does anyone have a wiring diagram too?
have some photos for your trouble
