gewy
Club RR Member Number: 82
I'll try to avoid dragging you in to help Don’t worry, be pleased to give you a hand as it progresses Anyway once I get to a point where I can stop for a bit haven't we got a Porsche 944 to weld up ready for #RRG15 - I'd rather practice on your car I finally have a car sized space in the garage
bstardchild
Club RR Member Number: 71
I'll try to avoid dragging you in to help Don’t worry, be pleased to give you a hand as it progresses Excellent I'll shout when the new body needs lifting Anyway once I get to a point where I can stop for a bit haven't we got a Porsche 944 to weld up ready for #RRG15 - I'd rather practice on your car I finally have a car sized space in the garage Blimey - How long ago did you have that?
Excellent I'll shout when the new body needs lifting I`m available for that too
bstardchild
Excellent I'll shout when the new body needs lifting I`m available for that too What with your recent deadlift practice you'd be ideal I'm under no illusion that if and when I get to that point I need to have a few things sorted Better weather - it has to be done outside Several cases of beer and soft drinks BBQ ready with plenty of meat ready to cook and lots of pasta salads and baked potatos And lastly Camera set up for time lapse so that we can verify the number of lifts it required before any welding could take place
bstardchild
OK tonight's progress Finished of cutting the back end off (left a little chassis rail just in case I need it) Apologies for the rubbish picture quality - garage camera batteries died and my mobile phone camera isn't quality Added the first extra brace The other side almost ready to do but I ran out of cutting and grinding time I think what I need to do next is go visit the Commodore and take some dimensions so I know where I need to take some more metal off
Enjoying watching the car destruction, in the name of the greater good! I take it since you still seem rather chipper about it all that the cage is not bent
bstardchild
Enjoying watching the car destruction, in the name of the greater good! I take it since you still seem rather chipper about it all that the cage is not bent I was wrong to ever have any worries about the cage bending - 48mm OD and a very substantial 3mm wall is a bit OTT for a cage (and a 75 kg weight) and it's doing a damn fine job right now keeping all the corners where they should be. Cutting has revealed loads of areas where in a year or two max major repairs would have been needed - whole time I owned the car I never noticed that one of the inner rear wheel arches was full of fibreglass!!! Nice bit is firstly most areas have been removed and secondly the ones that haven't I seem to have gained very easy access to make a few invisible repairs before the next stage.
bstardchild
Other side brace is in Normal service is resumed by garage camera after a night off Measurement time next - before adding less weight hopefully on Saturday as on the plus side it seems I have a free day in the garage Downside is the tea fairy (Mrs BC) is going to be at work - still 3rd world problems and all that - it's not like I can't make my own tea
Carter
Destroy to create. Excellent stuff, this is looking great! Hopefully see you this season!
'77 Chevy G20
...before adding less weight... I think you've already gone quite far with that one!
stuey
ram thruster 4000
I wondered why I hadn't seen this in a while Ian- its nice to see you didn't give up on it after crashing, I was thinking of it a few weeks ago on my first ever track day passenger ride which ended in the crash rail at corams at snetterton. keep it up!
1987 fiat 126-nearly actually done! 1972 beetle - lawn art 2003 z4 daily-new wheels a comin! 2008 R56 Mini cooper "mental Mickey"
bookmarked, unbookmarked, bookmarked, unbookmarked then bookmarked again just to outbookmark everyone elses respectful bookmarking gestures
bstardchild
bookmarked, unbookmarked, bookmarked, unbookmarked then bookmarked again just to outbookmark everyone elses respectful bookmarking gestures You got the right thread
bstardchild
Destroy to create. Excellent stuff, this is looking great! Hopefully see you this season! So far it's going in the right direction ...before adding less weight... I think you've already gone quite far with that one! Nope lots more metal to come out yet I wondered why I hadn't seen this in a while Ian- its nice to see you didn't give up on it after crashing, I was thinking of it a few weeks ago on my first ever track day passenger ride which ended in the crash rail at corams at snetterton. keep it up! Sorry to hear you had an off - hitting crash rail does a lot of damage unless it's a glancing blow I'm still cracking on with it but today I didn't achieve much - I emptied the commodore out and then measured and measured again until I was happy that my plans hold water - Bonnet release unfortunately has given up so I didn't quite work every thing out that I wanted too. Then I loaded all the stuff back in the Commodore for safe keeping and came home to measure what's left of the Monza and after further measurements with gewy over a coffee and a bacon sarnie we concluded I have two problem areas to worry about, this pleased me as just two was way less than I thought I'd have... I do however need to do some more cutting....
bstardchild
So critical dimensions on the Commodore Inside edge of A Pillar across the car from one side to the other 1390 mm Inside edge of the door shut closest to the opening end of the door to same place the other side 1390 mm Inside edge of the edge of the rear panel next to the wheel arch to same place the other side 1390 mm Inside the boot (inside edge of the wheel arch where it meets the body Any guesses........ Yep 1390 mm Did a load of height measurements from Sill top to check out roll cage clearances as well front cross bar on the cage I think is going to give me issues so may have to replace that with a straight bar
envoycdx
North East
I need my Mojo back!
Interesting project - and looks like it is going to be one of those measure 1 million time, take a mm off type of love affairs to get everything just so. Bookmarked
bstardchild
Interesting project - and looks like it is going to be one of those measure 1 million time, take a mm off type of love affairs to get everything just so. Bookmarked I'm not that accurate to be down to a mm It's gonna be a measure twice - make the odd template cut to that and then bridge the gap with a mig
Predicting this will be amazing when it's done
bstardchild
Predicting this will be amazing when it's done Or you and others are jinxing me I'd like it to be good when done but I've a long road to travel yet Back to cutting tonight
envoycdx
North East
Interesting project - and looks like it is going to be one of those measure 1 million time, take a mm off type of love affairs to get everything just so. Bookmarked I'm not that accurate to be down to a mm It's gonna be a measure twice - make the odd template cut to that and then bridge the gap with a mig Close enough
