Colonelk
Club RR Member Number: 83
Feb 17, 2015 19:39:00 GMT
Hi guys, probably time to do a thread about this..... 1984 Vauxhall Carlton 1.8 (G?)L Bum basic. No engine. Fairly rust free. The sill needs a little love, and the battery tray is a bit crusty but otherwise its ok. The strut tops have had an ugly repair in the past, but it looks solid so it'll do. Some more pics...... The future. Now, these isuzu 1.7s have a central sump on the cavaliers, half made of cast ally, and half pressed steel.... no good for the cross member, no good for remaking. Luckily they were made of fully pressed steel on the combo vans, and have a good rep for rotting out..... which means plenty in the aftermarket super cheap. SO I bought a new one to hack up. Trial fitting the engine in place, it sits pleasingly far back. Unfortunately, that makes making a sump a bit tricky! Measure Choppy chop (and remake pickup) Find some steel. Yugo roof should do. Start welding up Well.... it might work! Hmmmmm found this laying around, says Iveco. Probably do. LIKE A GLOVE! Battery tray wont be any use....lets pull it out. Literally. Silly gearlever So yeah, I should probably mention the Supra CT26 turbo and Eaton m45 I have to go on as well. This is a bit of fun experiment really. The Isuzus have a rep for strength. I'm going to see if thats well founded Project aims. 50mpg and 200bhp. May prove to be a fools errand, but hey, this is meant to be just a learning experience for me.
bstardchild
Club RR Member Number: 71
Feb 17, 2015 22:55:49 GMT
Checks favorite thread tick boxes
Opel Vauxhall content - Check Welding required - Check (kinda obviously goes with ^ above) Transplant Element - Check Future plans of a daft nature involving more powerz - Check RWD content - Check Silly Stuff - Check Runs on petrol not oil - Not Checked
Oh well nearly all boxes checked so please pass go and collect your £200
Mark
Feb 17, 2015 22:58:33 GMT
I like this.
Feb 17, 2015 22:59:05 GMT
Very cool thread, bookmarked this! Love an underdog.
qwerty
Club RR Member Number: 52
Feb 17, 2015 23:00:56 GMT
ERM well this is going to be rather brilliant!
Steve
Finally!!
This can only end awesome..you know it...I know it....hell everyone knows it!
Have you worked out how you are gonna be mounting/piping up the supercharger yet? That's the one thing both me and Si can't quite decide on so perhaps we need a group discussion....
Last Edit: Feb 18, 2015 9:19:19 GMT by Steve
nofrills
my wings are made of Steeeeeeeel!!!
bookmarked, this sounds crazy and i wanna see more lol
Feb 18, 2015 10:09:22 GMT
Pass the popcorn
Colonelk
Feb 18, 2015 12:34:20 GMT
Thanks guys, I hope not to disappoint.
You can all place bets now on likely first engine failure..... I'm listing them in order of likelyhood.
1. Head Gasket 2. Melted Piston / burnt valves 3. Clutch kerplosion (they are TINY as stock.... I have a plan but that may lead to...) 4. Gearbox kerplosion (also have a plan) 5. Rod out the side of the block 6. Cracked head (ok may be more likely than that)
Steve..... initial mockup suggests s/c low down below where the alternator normally sits, and turbo facing back to front so that it can breathe in from the other side of the firewall for nice cold air and fire the boost straight into the inlet of the s/c (on the back of it). Only problem with that is working out a sensible exhaust root. Its still TBD. I just want to get the mounts made before I make the s/c mount. This reminds me I need to order an exhaust mani flange.
The thing that will slow this one down are that I have 1 day a week to work on it, and cashflow. I'm trying to keep it on a low budget and I don't think any individual thing has cost me more than £100 with the exception of the car and that was £170.
This ones staying china blue, but may have some fun colour coding if I get time.
micrat
Building a Kanjo styled Cinquecento :)
Feb 18, 2015 12:55:00 GMT
Love this, and I'm sure it will be suitably awesome - will make a good combo with the blue monza! Must get to TAB again once mine's finished - happy to help
Last Edit: Feb 18, 2015 12:55:11 GMT by micrat
recarouk
Yorkshire and The Humber
Feb 18, 2015 20:08:54 GMT
my dad had an 84 carlton in royal blue when i was a kid, such a soft spot for these so ill be watching with great interest
Feb 18, 2015 20:23:10 GMT
YES!!!!!!!!!!!!!
That is all.
EmDee
Committer of Autrocities.
Club RR Member Number: 108
Feb 18, 2015 21:53:33 GMT
This can only end in tears.
Of joy.
Much love fo this BroDawg, can't wait to see a plume of black smoke pouring from the wing and mixing with the white from the rear tyres. Gonna be ***king MAGNIFICENT.
Feb 18, 2015 21:59:35 GMT
watching too. might even do something with the isuzu/carlton box ive had waiting for two years now!
do you happen to know what 'veco that intercooler is off? it looks cock on for something ive got in the works.....
omega
Feb 18, 2015 22:43:44 GMT
what gearbox does this use?
Ohhhhh, yes. *n
Feb 19, 2015 10:35:28 GMT
This thread appears to have all the ingredients for a 10 out of 10 automotive stew and I'm looking forward to seeing it all come together!
MORE...!!!!!!!!
***GARAGE CURRENTLY EMPTY***
craig1010cc
Club RR Member Number: 35
Feb 19, 2015 12:31:15 GMT
This does have all the signs of being an awesome project Is the plans that this will replace the scavalier for daily duties?? What are you doing gearing wise, I would have thought that a 1.8 petrol box and diff would be a bit low for teh TD lump?
Feb 19, 2015 14:31:26 GMT
this is now a straight up bookmark-off with the monzadore
