Feb 18, 2015 21:17:00 GMT
so I ordered a turbo for my Hillman hunter project car which should be here Friday or just after... was going to make a link to my build thread but don't know how so just go through my profile to get to it if you're interested haha
anyway ive been looking at getting the fuel system on the engine bay side of things uprated to match the new fuel system in the boot and also cope with a turbo
I started looking at aftermarket fuel rails, mainly the awesome looking flyin Miata purple ones, but nearly had a heart attack when I saw the price!!!
then I remembered I'm an engineer.... ha so I thought why not make one from scratch! got a block of Ali and came up with a rough design taking measurements from the standard rail
so pics of the progress so far, will keep up to date as I get on with it
the standard rail and what the new one will be made from;
this is a simple drawing of my design... I'm sure it will change as I go on to accommodate for things I've forgotten haha;
my plan is to drill all the holes and pipe lines and stuff while its a nice square block, then profile it afterwards, so first thing is to bore a hole through the entire length;
the hole drilled without any mishaps thank Christ! 9.5 mm hole 13" long haha;
there's light at the end of the tunnel!!!
that's as far as I've got so far but should get more done tomorrow after work so i'll keep this up to date
Last Edit: Feb 18, 2015 22:06:14 GMT by code109
Feb 19, 2015 10:21:00 GMT
My goodness, drilling a hole through 13" is a task in itself, dd you part drill form each end or find a mega long drill from somewhere?
I'm surprised it didn't wander, at least the most risky operation is out of the way,
I'll be watching this progress as it'll be an interesting project for you.
Brian
Feb 19, 2015 16:21:44 GMT
yeah I approached it from both sides, just went extremely steady, feed rate of 20mm/min haa... although the trueness of the two holes meeting up is testimony to the machines in my work! but yeah everything you said is exactly why I did it first, even before I squared the ends up
Feb 19, 2015 16:27:56 GMT
We see a few made this way come into our workshop. They all go for the real ones in the end. Still have these laying about the place.
Feb 19, 2015 17:16:29 GMT
do you know of any issues that arise? or anything I should bare in mind?
Feb 20, 2015 19:34:26 GMT
okay got more done this evening, couldn't do anything yesterday due to an absence from work with suspected food poisoning haaa
anywayyyyyy I squared up the ends to the correct length and have all the holes drilled now, just profiling next...
the holes for the injectors, i'll insert stainless "cups" to sit the injectors in;
and the holes for mounting, and the fuel in pipes and return / pressure regulator take off;
and the injector side again;
I'm hoping to pop in for a bit tomorrow morning so should have it completed and ready to fit some stainless injector cups (have to turn them still) will keep updated for anyone interested
sowen
Club RR Member Number: 24
Custom Fuel Railsowen
@sowen
Club Retro Rides Member 24
Feb 20, 2015 21:00:51 GMT
Really nice stuff, keep it up! Looking forward to the finished article, inspirational stuff
v8
Feb 21, 2015 16:26:34 GMT
Nice job so far
Feb 21, 2015 19:14:10 GMT
Just don'take the holes/lines too small. Well work ok no problems
v8ian
Feb 21, 2015 20:48:00 GMT
Holes for the fuel don't need to be massive, 6mm is ample I ran a engine with 330 hp with 8 injectors on a 6mm id pipe,
Feb 24, 2015 14:55:06 GMT
Cheers guys Started roughing out the profile; Then finished the profile and tried the regulator take off in place; Started turning down stainless m16 bolts for the injector cups; Thread locked them in place ready to be machined; Also got a bit artsy and put a simple design on the top; All that's left is to machine the cups and plumb it in
Last Edit: Feb 24, 2015 14:59:28 GMT by code109
sowen
@sowen
Feb 24, 2015 15:05:51 GMT
Much tool envy That is very impressive stuff, love it
Feb 24, 2015 23:57:17 GMT
Last Edit: Feb 24, 2015 23:58:57 GMT by code109
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Feb 25, 2015 10:50:22 GMT
Very nice work
Feb 25, 2015 11:59:17 GMT
Lovely work. Out of interest if the place you work at was to price this up as they would any other job, time, materials, set up and design with a modest production run how do you think it would compare to the flyin Miata purple ones you first looked at?
Feb 25, 2015 12:56:56 GMT
Cool. Keep the updates coming.
Feb 25, 2015 14:55:21 GMT
Thanks everyone much appreciated Lovely work. Out of interest if the place you work at was to price this up as they would any other job, time, materials, set up and design with a modest production run how do you think it would compare to the flyin Miata purple ones you first looked at? I honestly wouldn't like to say, I mean I got the block of Ali for free from an old mate at a different engineering company but that wouldn't be cheap Then it took me about 8 hours in all which is a days work, so you'd be looking at around 300 just for the labouring costs... When the flyin miata ones are 200 - 300 with the plumbing fittings and stuff so...... :/
Feb 26, 2015 18:17:36 GMT
Now you can tell people it is priceless! Keep up the great work.
