Rob
You know, for kids!
Feb 19, 2015 23:10:36 GMT
I have a Marina that's been converted to coilover struts on the front end. This has left some sizeable (but not structural) holes in the inner front wings.
I'd like to construct an inner wheel well from plastic and wondered if anyone had done it and what they had used? It isn't a full arch so an existing inner liner won't be much use - is there any sheet material i could use?
Any advice appreciated! Cheers - Rob
Feb 19, 2015 23:29:47 GMT
I need to make something and someone passed me this info....
"I've use the ABS sheet modding method before. Warm it with a heat gun to mould by hand, then join and seal the sections together using black PU body sealant. Gives a really nice pro job..."
scimjim
Club RR Member Number: 8
Feb 19, 2015 23:44:45 GMT
200L plastic drum/water butt are ideal if you can find them cheap.
Rob
You know, for kids!
I need to make something and someone passed me this info.... "I've use the ABS sheet modding method before. Warm it with a heat gun to mould by hand, then join and seal the sections together using black PU body sealant. Gives a really nice pro job..." Cheers for that I was wondering what to bond the pieces with 200L plastic drum/water butt are ideal if you can find them cheap. Hm... I'll keep my eye out, cheers!
Feb 20, 2015 11:45:00 GMT
Feb 22, 2015 19:34:07 GMT
I tried to make inner front arch splash guards for my E24 using moulded liners from an Omega and black 25lt plastic drums . I cut them down to get the largest section of sheet I could with the intention of adding them to the liners to get the coverage that needed but found that even after getting them as flat as could using a heat gun they had a slight "memory " effect and would curl up again destroying any fit I had adjusted them to. It's a difficult material to work with .
scimjim
Feb 22, 2015 21:33:12 GMT
yes - 25L drums won't work, you need a much bigger radius
Feb 22, 2015 22:44:34 GMT
yes - 25L drums won't work, you need a much bigger radius Yep , that would make sense . Cheers
Feb 22, 2015 23:26:48 GMT
Have you tried the mudguards they put on rally cars.halfrauds sell a similer thing it's a square of flexible plastic
Feb 24, 2015 10:37:59 GMT
The stuff the rally cars use is called Kaylan
"plastics for performance" is your first port of call
Rob
You know, for kids!
Missed these responses - how do you get email alerts on this forum? I thought bookmarking would be enough. Edit: Found it.
I'll check all that out, cheers for the info.
Last Edit: Mar 11, 2015 9:53:59 GMT by Rob
*** bodge mode activated ***
Milk bottle plastic is nice and flexible if you cut the neck and base off - get a few 6 pinters.
fix them in archwell and spray black.
*** bodge mode de-activated ***
Rob
You know, for kids!
haha - It will need to be a bit sturdier than that!
