hairymel
avatar by volksangyl
Club RR Member Number: 207
Dirtrod diary - on the Marchhairymel
@hairymel
Club Retro Rides Member 207
Feb 26, 2015 23:12:38 GMT
The question has been asked of me many times 'whats happening with your sunbeam?' the stock answer has been 'not a lot' as penance i offer up a thread about what i have been up to. last year i did this: last year i started racing at stansted raceway in the dirtrod class, a 'limited' contact formula on a dirt oval. i probably spent about £600 for a season of racing including building the car. great fun not quite as pretty at the end of the year though this year (hopefully) as well as racing a dirtrod @ stansted i hope to race at arena essex in the 2.0 fwd hotrod class. it all started when a unit buddy left his manbag on the train....
Last Edit: Apr 24, 2021 15:46:37 GMT by hairymel
whats that burning smell?
oh curse word :-(
hairymel
@hairymel
Feb 26, 2015 23:28:39 GMT
chapter one - hotrod (not that sort) ford puma build late one evening i received a text message from charlie 'i have lost my keys and my puma is stuck in the railway station carpark. do you want to buy it for £250?' cut a long story short - i was very drunk, charlie was very desperate and a more agreeable price was agreed skip forward via a friendly recovery truck owner and a £20 ebay ecu and keychip bring us to here and unfortunately leaves the sunbeam here
Last Edit: Feb 28, 2015 23:32:55 GMT by hairymel
oh curse word :-(
hairymel
@hairymel
Feb 26, 2015 23:38:08 GMT
Last Edit: Feb 26, 2015 23:41:55 GMT by hairymel
oh curse word :-(
hairymel
@hairymel
Feb 28, 2015 23:00:54 GMT
thankfully I have a bit of a backlog of updates, as progress has been a lot slower than i hoped (nothing new there ) pleased with the fit of the main hoop i carried on with the front legs i also tacked in the dash bar (this moved position 3 times during the cage build and is still wonky ) roof bracing bars in the front bodywork also came off and after at least 2 weeks of mostly looking at the job i removed the glass time taken 3 months (seems to mostly have been moving the other cars around in the unit!), total spend £300 (christmas presents to myself of mainly safety hardware - door net, fia switch and a shiny start button panel )
oh curse word :-(
eternaloptimist
Good work there.
hairymel
@hairymel
thanks eternaloptimist its the first cage i have made on my own and have only helped with 3 others. the next one will be better
oh curse word :-(
hairymel
@hairymel
fast forward a bit as i had a burst of enthusiasm (but i seem to have not been taking photo's ) and a few more tubes are in first i had cut 50mm off the main hoop and front legs to allow me to fully weld around the tops of the tubes, and then welded a length of 50x50x3mm box section along the inner sills to support the cage. after this the other tbes were fudged in. nascar style door bars and cross rails with seat mounts for some reason this is my favourite picture so far it was about this time that i looked closely at a picture of a 'hotrod' shell for sale on face book. after a quick internet chat it seems i have gone a bit overboard with my cage, as everyone else seems to find a much flimsier affair acceptable. i am fat/old/fragile so would rather be heavier/slower/unbroken time taken 11 weeks , total spend £300 (cant think of anything will adjust figures later on! )
Last Edit: Mar 1, 2015 12:56:57 GMT by hairymel
oh curse word :-(
gavs1
Can't ever put a limit on personal safety, gunna bookmark to keep an eye on you, we're building a stansted car it's all caged etc just can't maake our mind up what engine to use
hairymel
@hairymel
engine choice is easy - decide your budget then get the fastest one power does not give a great advantage at henham - getting round the corners is relativly more important. my fiesta was in the top ten for power but, until near the end of the season (when i made some major adjustments), handling issues gave me no chance of scoring any points.
Last Edit: Mar 1, 2015 13:38:51 GMT by hairymel
oh curse word :-(
that's a damned impressive cage! How did you make all the bends, as they don't appear to be crush-bends in the pictures?
gavs1
Raced at henham for a few years on and off, we had a 1300 Peugeot 205 that gave the bigger cars a run for there money, Engine choice we have is the 1.7 puma engine, 1.8 Ztech, fast Cvh, Vauxhall red top, 1.6 sigma engine, have a yard full a engines just more having time to make 1 fit in or do I rwd it,
hairymel
@hairymel
chairchild - the cage is 42x3mm tube so fairly hefty compared to minimum regulations (32x2.5 or 38x2mm)and is bent with ebays cheapest (£80 delivered from germany!) 12ton crush style bender. there is some rippling of the inner radius and a lot of flattening of the outer radius but most of the bends have come out acceptable for the job in hand. (some are a bit rubbish but all the mandatory bars are good) the expensive 'pipe' bender at work only does a slightly better job but still isn't as good as a decent tube bender. on the other hand £80 minimum spend isn't £1800 minimum spend. i made my choice and I am happy with the cost/performance ratio gavs1 all sound ok what car is it? go with whats quickest/easiest to fit - race season is only 27 days away
oh curse word :-(
Paul
Is this the one that'll be getting its first run at the start of May?
Last Edit: Mar 1, 2015 20:07:36 GMT by Paul
bstardchild
Club RR Member Number: 71
Dirtrod diary - on the Marchbstardchild
@bstardchild
Club Retro Rides Member 71
Appreciate the thread and I'm impressed with the cage very sturdy However I would prefer if you got stuck into the the sunbeam
hairymel
@hairymel
Is this the one that'll be getting its first run at the start of May? not sure if you are taking the proverbial, or just never listen to me... first missed deadline for this car was end of january, then next one is this saturday for test day. march 28th is first race meeting of the season so has to be finished for then! the (secret ) may event is for a less prepared spec of car..... car will probably be one of these with the headlights and tail-lights removed and the bonnet strapped shut that is all for safety prep.. don't bring your best underpants
oh curse word :-(
hairymel
@hairymel
I would prefer if you got stuck into the the sunbeam hangs head in shame the final product should be better for this diversion - hopefully
oh curse word :-(
Paul
It's just that you have so many cars on the go at once...
I'm on holiday for the Puma's debut...sad times...
bstardchild
@bstardchild
I would prefer if you got stuck into the the sunbeam hangs head in shame the final product should be better for this diversion - hopefully Excellent new - as long as it doesn't end up Fiesta shaped we will remain life long friends
hairymel
@hairymel
aaah thanks ian edit to add macho pirate smiley
Last Edit: Mar 1, 2015 22:15:01 GMT by hairymel
oh curse word :-(
eternaloptimist
Just idly wondering if you stash the Puma away at the end of the season.......wind forwards 20 years........some Puma enthusiast finds it and starts a thread showing how they're putting it back on the road.....
