Feb 27, 2015 13:33:21 GMT
Ok, bought a 925 off a chap on the 924 owners forum. It is a total so and so today tart, then when it does start it misses and sounds lumpy like it's running on 2/3 cylinders. I've checke all the normal thing like fuel, air leaks, compression etc.. Started checking timing, seems all good, flywheel marker lines up with cover marker etc.. Except.. From all the info I have found online, it says the leads should go clockwise 1342 from where rotor arm sits at tdc but mines set anti clockwise. I changed leads round to do this and it just backfired and won't start! So am I being mislead or am I some how confusing clockwise? :/ here's a picture to try and elaborate. So bottom left is 1 (where tie arm points) clockwise from there top left is 3, top right 4, bottom right is 2? Am I going mad?
Fact : firing order is 1-3-4-2 according to www.porsche924-944.nl/manual/Haynes/05_Ignition.htmUnless anyone comes up with any better ideas try ... Quickfix : Expect a pair of plugleads to be mixed up, remove leads 1 at a time and try to start it - if worse you have just removed a "good" lead (put it back ) if no worse flag it - repeat until you find the other "wrong" lead and swap them over (or just swap leads 3 & 2, then go for it ) Proper check of pluglead order : turn off ignition, make all checks with ignition off to save shocks! remove distributor cap * option A - make sure next step is compression stroke if possible not exhaust stroke (maybe remove plug #1 and put finger on hole to confirm ?) Turn engine to just before TDC on cylinder #1 (line up firing marks), expect rotor arm to be pointing to pluglead #1 (bottom left in your pic) * Option B - if it's pointing to #4 and you didn't check for compression stroke, just rotate engine 360* to get rotor arm pointing to #1 Now check - pluglead #4 on cap has to be opposite pluglead #1 Manually turn engine crank 180* - note direction rotor arm turns - rotor arm should move 90* to next pluglead ** check this is pluglead #3 Now check - pluglead #2 has to be opposite pluglead #3 I've answered the easy "it's broke - how do I fix it" question, I'll leave the difficult stuff for somebody else
I thought the firing order was stamped on the cam cover or am I remembering wrong?. Make sure you set tdc off the cam and crank because my last one had an extra mark on the cam sprocket that threw me when I was timing mine up.
sweaty palms slip off joystick
Thanks guys, yes the firin order is on the can cover, it just the direction it goes on the dizzy cap. As I was told clockwise from tdc mark and it does NOT like running like that :/
stevek
Yorkshire and The Humber
I think I had the same miss-leading cam sprocket marker problem as spandelly had. There are some pictures on pg1 of my 924 thread (click link in my sig). -Steve-
Last Edit: Mar 2, 2015 22:38:24 GMT by stevek
roar the engine over with the cap off so youre 100% on what way the rotor spins , then there should be a little line on the edge of the dizzy to show where number 1 is
Y I've got it timed up correctly I believe. I'll give it ago to see which way it spins, thanks.. Hadn't thought of that!
And I looked at the shonky rocket thread for efferent before.. Good read!
