The car is a '81 280e, and I'm trying to get the starter motor off. The bottom bolt is out, but the top one appears to need a 10mm allen key with a flexible handle to clear the gearbox.
What's the easy way please?
Mar 25, 2015 11:15:17 GMT
This is getting embarrassing. The car is a friends, who is rapidly losing confidence in my abilities. I have tried many combinations of this lot; Both from above and below, but there is just NO ROOM to move any tools about. Before I try to make an allen key that looks like a curly straw, can anyone offer any advice please. This is the little blighter; . . . thought w123s were designed to be fixed at the side of the road . . .
Onne
Mar 25, 2015 12:04:37 GMT
Sent you PM
If you undo the gearbox mount and let the engine drop down a bit at the back you can get in there with the allen key attached to two socket extensions.
Hope that helps, Dave
If you undo the gearbox mount and let the engine drop down a bit at the back you can get in there with the allen key attached to two socket extensions. Hope that helps, Dave Thankyou, thankyou, thankyou. I would never have thought to do this, worked a treat. And thanks to onne too.
