Mar 22, 2015 14:37:49 GMT
So, I'm in need of some custom oil pipes (turbo oil feeds) and whilst in my mind, it should be fine, I'm just after reassurance....
Can I use "fuel/oil" pipe, rated to 75 bar, with barbed fittings, and fuel hose style clamps (NOT jubilee clips) with no fear of it popping off, or generally leaking?
The pressure is well within the range of the pipe, the barbs give plenty of grip/seal... But I don't fancy finding out the hard way, lol
Mar 22, 2015 14:47:03 GMT
Have a look at earls hose or aeroquip to see what theres are like
Mar 22, 2015 14:55:25 GMT
Used earls pipe before - similar construction, but clamped in place via a compression style fitting on the rubber (like a built in clamp)
They do look awfully pretty... But damned expensive in comparison
Kieran
Mar 22, 2015 15:53:50 GMT
Just go to an hydraulic hose supplier and have some proper hoses made up with crimped bsp ends.
Surprisingly cheap and a good permanent solution.
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
Mar 22, 2015 17:09:42 GMT
I'm sure it'll hold up a (short?) while using dual high quality hose clamps. But i agree with Kieran, for a few tenners more you'll get peace of mind.
Last Edit: Mar 22, 2015 17:20:07 GMT by dude
Mar 22, 2015 18:59:52 GMT
Drop me a PM with the dimensions I can get them made to spec for
Mar 22, 2015 21:27:41 GMT
Swampy what sizes and dimensions do you need to get some made up? I don't need any currently but I will eventually when the turbo goes onto my pinto. Thanks
Mar 22, 2015 22:34:29 GMT
TBH, only needs to last a few months, before I just slap on a bigger turbo - but will get the dimensions tomorrow Literally about 2 foot of pipe, with (IIRC) an 8mm banjo fitting either end. Any idea of a rough ballpark figure?
Last Edit: Mar 22, 2015 22:35:49 GMT by chairchild
Mar 23, 2015 18:45:20 GMT
Basically need to know what length you need and what fittings on each end
Price would be sub £25 delivered
Mar 23, 2015 18:58:15 GMT
Just go to an hydraulic hose supplier and have some proper hoses made up with crimped bsp ends. Surprisingly cheap and a good permanent solution. definitely this, if you have any of the original fittings that will help a lot too.
Mar 23, 2015 21:01:44 GMT
original fittings?
This is a daisy chained oil feed, for a twin turbo setup - "original" parts don't exist, lol
Also... *why* would nobody use high pressure pipe, barbed fittings, and decent clips? Fear of the unknown, or is there a genuine reason? As stated, I've used Earls pipe fittings for a turbo oil feed in the past, and it's very similar in construction....
Mar 23, 2015 21:25:51 GMT
Can I use "fuel/oil" pipe, rated to 75 bar, with barbed fittings, and fuel hose style clamps (NOT jubilee clips) with no fear of it popping off, or generally leaking? No! Been there, tried that, dumped the whole sump on an A4 roundabout.... (oil cooler hose came off)
Mar 23, 2015 21:45:57 GMT
and there we go PM on its way!
