Mar 22, 2015 19:16:17 GMT
Don't need a Rolls Royce as its for our son to do some Design Technology work on for school. Have cash will travel don't mind a project but not one that's been at the bottom of the sea!
dealy
Mar 22, 2015 19:45:06 GMT
i may just have the thing were doing a workshop clearance theres a lathe i dunno what you class as small or large though I'm in witham essex
Mar 22, 2015 20:52:36 GMT
Keep your eye on homeworkshop.org as well, stuff like this comes up often.
If it's small scale the cheep Chinese stuff can be a good starting point, they might be rough around the edges, and with a little fettling can be a lot better than out the box, but they won't be worn out before you start. The bench top ones can be had for a few hundred
That said I used a well worn Harrison L5 for a couple of years and with care good things could be made and I learnt a lot.
Brian
Mar 23, 2015 14:12:57 GMT
Keep your eye on homeworkshop.org as well, stuff like this comes up often. If it's small scale the cheep Chinese stuff can be a good starting point, they might be rough around the edges, and with a little fettling can be a lot better than out the box, but they won't be worn out before you start. The bench top ones can be had for a few hundred That said I used a well worn Harrison L5 for a couple of years and with care good things could be made and I learnt a lot. Brian Thanks I will have a look, only one I found local looked like it had been at the bottom of the sea and whilst I don't mind a project it was beyond hope!
Mar 23, 2015 14:13:54 GMT
i may just have the thing were doing a workshop clearance theres a lathe i dunno what you class as small or large though I'm in witham essex Thanks I am miles away but might be worth the road trip, let me know price size etc
Mar 23, 2015 15:59:46 GMT
i may just have the thing were doing a workshop clearance theres a lathe i dunno what you class as small or large though I'm in witham essex Sorry to hijack. How much are you looking for it? Have you got any pics?
Mar 24, 2015 15:16:15 GMT
I have a good myford ml7, its my first lathe but I want a larger one now as most of the stuff i need to machine won't fit now. It is old, but these are well known and have loads a buts available and que accurate. I'm after £600
Mar 24, 2015 19:46:28 GMT
I have a good myford ml7, its my first lathe but I want a larger one now as most of the stuff i need to machine won't fit now. It is old, but these are well known and have loads a buts available and que accurate. I'm after £600 Thanks buts thats way better than he needs and a bit over budget
Mar 24, 2015 19:50:01 GMT
No problem, war i do some smaller units come up second hand for a few hundred.
Mar 26, 2015 17:34:53 GMT
I have a small hobby lathe. Its old but the motor runs and I fitted a new belt as the one on was perished. You could do a piece about 44cm long at the most. Send me a pm and I can send you some pictures if you like I'm in the northeast but could pack it up if you want a courier
Mar 30, 2015 10:56:25 GMT
I have a small hobby lathe. Its old but the motor runs and I fitted a new belt as the one on was perished. You could do a piece about 44cm long at the most. Send me a pm and I can send you some pictures if you like I'm in the northeast but could pack it up if you want a courier Send me a pm with some contact detail and a photo if you could please. How do I set a thread up so it Emails me when some one replys?
eternaloptimist
Mar 30, 2015 18:52:16 GMT
Hi there - responded on your thread on VZi, missed this thread somehow.
