I have a 1968 AMC Rebel SST. It has 14" steel wheels, 6" width and with a pcd of 4.5" (5 stud).
As it happens this pcd also 114.3 as used on some J stuff.
As far as I can tell, the offset/backspace is zero.
The original tyres fitted were cross ply (bias ply if you in the USA) 7.75 X 14.
When I bought it almost 9 years ago it had Van (commercial) radial tyres fitted - 195 14 on the front and 205 14 on the rear. I suspect these were fitted as they have a tall profile so are closer to the original rolling diameter.
I've been on the lookout for a set of alloys or wider larger steels for the last 9 years - but everything seems to be silly prices.
As it happens I have two sets of alloys in the garage - both ET50, one with 5x112mm pcd, one with 5x100mm pcd. I have located an outfit that can custom make adapters in pretty much any size.
So, at last, the questions -
If I get 50mm spacer/adapters that should take me back to zero offset using the ET50 wheels right?
If I get 60mm, that will be "pushing" the wheels outwards by 10mm?
If you're wondering why I'm so keen to use these alloys - I already have them so they are cheap, and they have decent quality recent Conti tyres on, instead of the Crappy ancient van ones.
All answers, abuse and suggestions gratefully accepted.
