Apr 18, 2015 13:00:09 GMT
Apr 18, 2015 13:14:50 GMT
how heavy is the car? Not used myself but have seen a few folk using ones you jack the axle up then slide a dolly under each week, like this www.machinemart.co.uk/shop/product/details/awd1-automotive-wheel-dolly-pairThe ones you found look different - I guess you slide them around the tyre then the built-in jack lifts the car. First thought is how long will you have the car in the air - yours will leave 2 pressure-point on each tyre, fine for moving then lowering but best avoided if you want to keep moving it around. abviously - these only work on decent flat floor, not best on cracked concrete.
Last Edit: Apr 18, 2015 13:16:29 GMT by nomad: fix link
duncanmartin
Out of retro ownership
Club RR Member Number: 70
Apr 18, 2015 16:16:25 GMT
Apr 18, 2015 20:38:37 GMT
It makes manoeuvering car around a doodle if you are on your own.
I occasionally play around with GoJak dollies and these are nicely made.
Click picture for more
gn3dr
Apr 18, 2015 21:26:00 GMT
I use them. They're great. Can move a car around on your own. Need a smmoth floor for them though.
Apr 18, 2015 22:29:44 GMT
The SGS ones are top notch and good value, as is all their kit to be fair
