Hi guys
My 85 trans am is running a 305 V8 (5.0) with the TPI injection system
Since owning the car it has had a missfire on at least 1 if not 2 cylinders. When driving at what the car drives beautifully , however when cruising and also when holding the revs in neutral it can be made to missfire when holding revs
I have changed the fuel filter, dizzy cap, rotor arm, 02 sensor, plugs and lead with no results.
Anyone have any idea where to go next ?
I'm thinking it could be injectors which will be a curse word of a job as it means a lot of new gaskets and also injectors arent the cheapest
anyone else experienced this?
