Hi all, I have a problem on my daily and I'm hoping you guys can help. It's a modern but I guess the fundimentals of brakes are all the same?
It's a 2004 S-Type
Sometimes the brake pedal will travel as normal, then go hard, and sometimes it will only travel a fraction before going hard. In both occasions, the car takes ages to stop, scarily long.
I've done what I've been told is a servo test. Hold your foot on the brake and start the car and the pedal should move.... but in my case, it doesn't.
Does any one have experience they can share? The car has a servo and a vacuum pump, it's also a diesel, if that matters.
Thanks!
It's a 2004 S-Type
Thanks!
