robrs2
Apr 24, 2015 22:24:34 GMT
All part located in Teesside MT75 v6 4x4 box with front prop £150 MT75 Dohc 4x4 box £150 M75 2wd Dohc box £120 205 pinto 2.0 EFi with EFi inlet manifold £400 205 pinto transit 2.0. Head removed, standard bore. £200 sierra mk2 20 or 21mm? Rear ARB fit mk2 hatch or saff £40
Have you got the drop links to go with the rear arb? How much would postage be?
robrs2
Should have some links, i'll have a look. postage may be about £10 but i'll check
Apr 25, 2015 20:24:28 GMT
curse word I've just thought will the mk2 rear arb fit on 1984 mk1 shell? Something in my head is telling me that there are differences on the mounting points on the shell compared to the mk2, I wanted to fit a rear arb to my mk1 to tighten the rear up, I was planning on welding mounts to the arms for the drop links so I'm not worrying about that
If all else fails I could measure the mounting points on my saph and compare them to my mk1
Last Edit: Apr 25, 2015 20:50:51 GMT by fordperv
robrs2
Apr 25, 2015 21:16:07 GMT
I was thinking something similar would need to be done, did you make those mounts yourself? If you find out how much postage would be that would be great
robrs2
Apr 28, 2015 20:18:30 GMT
Postage £8. Not my mounts pic from fordpower forum
Apr 28, 2015 22:19:19 GMT
That sounds good, pm sent
Last Edit: Apr 28, 2015 22:26:15 GMT by fordperv
