Update on this, the breaker went and I have now sold my keeper so all of the spares I put aside for a rainy day are now available.
I want to clear them out to make some space for my next project. All taken from the low mileage 1993 316i Touring.
All cheap to clear, I'm not looking for big profit just after a few quid to help with project funding.
Big/heavy stuff will ideally need to be collected from North Bristol or I could bring stuff to work in Cheltenham for collection during office hours if that helps. All prices are collected, smaller items I'll post at cost.
If it's not listed just ask, I may still have it, I just haven't sorted through all the boxes yet.
£30 (*** Provisionally Sold ***) Rear set up, what you see in the photo apart from the ARB.
ideal for rear disc upgrade. Trailing arms are ABS compatible.
£5 2x ABS sensors - rear
£10 Rear calipers
£5 ECU from drivers side
I've also got the ECU type box from the behind the glove box, not sure what that one is for??
£15 (*** Provisionally Sold ***) Good diff, no whines.
I'll even include a BRAND NEW bush and 1litre of Diff oil There is a bolt stuck in the shaft. The head had rounded so I cut it off, it will probably come out with a squirt of stuff and some vice grips but I haven't even tried. (provisionally sold, awaiting confirmation)
£5 filler neck, surface rust but solid. Would be ok for shot blast and powder coating.
£20 high temp painted exhaust manifold - I'll include a nearly new gasket with heat shield to protect plugs and leads
£40 load cover with pull up dog guard - grey
£8 1 pair of front mudflaps. Please see the condition from the photos. one of the tabs is broke, the other will probably brake if you try and release that rusty bracket. But I'm sure someone could work out an adequate way to fix them on.
Some other stuff I can think of but don't have picture yet. I will when I sort out the garage
£15 Steering rack, pump, reservoir and pipes - Good working order no play. Will need new TREs.
SOLD - box of headlight spares. Smiley face. I'll get a pic, but there's enough for 2 complete units, plus some extra lens.
£20 Airbox and MAF meter
£10 Starter motor
£10 Alternator
£10 dizzy cap
£10 HT leads, with the cover and the sensor lead
£10 drivers seat belt
£5 fuse box cover
£10 Every fuse and relay from the fusebox
SOLD - service light reset tool
£5 Good clean washer bottle
£5 each - various switches, electric windows, rear demist, rear wash wipe.
£5 pair of scuttle tray vents
£5 1 only, front strut insert BOGE, brand new in box. I'll need to check part no. and size.
SOLD - original orange wing indicator repeaters pair
£10 accelerator pedal
£10 front brake calipers - needs attention, one side was starting to bind
£5 EACH - Black bumper trim inserts: rear corners and front passenger side (provisionally sold, awaiting confirmation)
£10 BBS 15" centre cap bits; centre nut and black plastic bit, NOT the metal waffle plate
£30 Heater valve, has some signs of corrosion but didn't appear to be leaking when fitted.
£2 ashtray
£15 Touring boot side panels with speaker grills (not flaps) and rear panel that covers the lights, grey carpet
£30 full set of seat belts
Various trim clips, cable fixings, nuts, bolts, screws etc.
As I sort out the garage I'll photograph and list more stuff.
Happy to do deals on multiple stuff and will post any of the smaller stuff.
