Feb 15, 2019 20:28:00 GMT
some awesome looking welds there, looks almost machine made Wooof ! that's what i like to hear ok dokey a little micro update , clutch basket was too big to fit on the lathe, to smooth the welds, down so i did it by hand , and then drilled out the holes again , also went and got a load of 1/4" bolts for the straps on the clutch where i drilled the rivets out , all looks pretty ok ish in a totally different direction , i made the mistake of turning on the ignition the other day ,with v's smart charger connected to the battery and sending out its high voltage pulses , this fried the digital thermometers . .. so i bought another pair from that place beside Taiwan , and they arrived today so i could put all the dash back on the car .. YES , the "back to the future" part of the car is alive again (or hg wells "the time machine" take your pick) regards robert
Last Edit: Feb 15, 2019 20:44:53 GMT by ivanhoew
Feb 15, 2019 21:05:18 GMT
I would love to see a video of you driving it at 88 mph Robert.
tristanh
Routinely bewildered
Feb 15, 2019 22:51:36 GMT
Lovely strong and even welds there Robert. Not many people would have the balls to build their own clutch.
Lovely strong and even welds there Robert. Not many people would have the balls to build their own clutch. Thank you Tristan Re clutches , i have been building them for a few years , in the vintage turbo mini world we used to have a drag race every year at avon park , and we got to the stage where the double grey and paddle plate would tend to slip or/and knock out the thrust faces on the crank ..so i designed and developed a verto clutch with two springs in it . this has worked well ,and our fastest mini(hi nic) is running mid 12s on yoko 32's with no clutch slip .My mini would only manage a poxy 13.1 , but i was 75 kg heavier and on an open diff and falken tyres ;( testing the first experimental verto clutch , with it being in line with your male components, was a pensive moment at 7k rpm . regards robert
Feb 21, 2019 19:47:16 GMT
hello chaps .. Now , i know its not very exciting ,compared to car design and building stuff , but i had a bit of a dyno sesh with the old girl , and wondered if it would be of interest ? i set up two separate wide band data loggers, another puter logging the exhaust gas temps on each run , and also the normal bhp and trq recording , it all got a bit mission control at cape carnival .. Bearing in mind the car is still running v unevenly cross the cylinders , and that the clutch is definitely slipping , would anyone care to enjoy guessing what the bhp and trq figures were ? last time it was on the dyno it had 170 hp at 3200 ,and 306 lbs/ft at 2500 ... regards robert.
scimjim
Club RR Member Number: 8
Feb 21, 2019 19:53:21 GMT
250 & 350 at 4000 š
Feb 21, 2019 20:04:03 GMT
10,000 hp and 6,793 torques.
sonus
Feb 21, 2019 20:45:53 GMT
Sufficient (as Rolls Royce used to state) š
Feb 22, 2019 10:07:06 GMT
warm 10,000 hp and 6,793 torques. that all mark ? Sufficient (as Rolls Royce used to state) š to break things ,definately !
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
Feb 22, 2019 10:25:35 GMT
300 horses and 400 torques
Feb 22, 2019 11:02:07 GMT
excellent , so we have :
scimjim.......... 250 bhp and 350 lbs/ft at 4k blackparpracing.. 4.2 gigawatts. overdrive........ 300 bhp and 400 lbs/ft
i am impressed how close these guesses are ....anymore out there ?
jamesd1972
Club RR Member Number: 40
Feb 22, 2019 11:06:09 GMT
275 / 375 ! James
mk2cossie
Club RR Member Number: 77
Feb 22, 2019 14:13:15 GMT
I'm going to guess at 380bhp and about 420lb ft of torque
Phil H
Club RR Member Number: 133
Feb 22, 2019 14:16:11 GMT
325bhp and 400lb/ft And I hope Iām under
eternaloptimist
Feb 22, 2019 14:51:54 GMT
310 bhp and 415 lb/ft
glenanderson
Club RR Member Number: 64
Feb 22, 2019 15:25:11 GMT
325 bhp and 450 lbs-ft @ 4200 rpm.
samta22
Stuck in once more...
Club RR Member Number: 32
Feb 22, 2019 16:19:02 GMT
No one has said it yet... so 330bhp and 430lb/ft
Feb 22, 2019 16:25:55 GMT
I say exactly double the first reading you did
Feb 22, 2019 17:25:26 GMT
286 horses and 343 torques
Feb 22, 2019 19:33:25 GMT
holey smokes ! it's a FEEDING FRENZY !! so , up on the old score board we have (in no particular order ).. scimjim...............250 bhp and 350 lbs/ft at 4k blackparpracing.......4.2 gigawatts. overdrive.............300 bhp and 400 lbs/ft James ................275 bhp and 375 lbs/ft Mk2@cossie............380 bhp and 420 lbs/ft Phil .................325 bhp and 400 lbs/ft eternaloptimist.......310 bhp and 415 lbs/ft Glenn ................325 bhp and 450 lbs/ft Sam ..................330 bhp and 430 lbs/ft bmwmaniac ............340 bhp and 612 lbs/ft rwdrules..............286 bhp and 343 lbs/ft A plethora of numbers ,well done chaps , i will put up the real numbers in a post tomorrow evening by the way ..both the correct numbers are in that mass above within 1 or 2 , but not by the same person ...... regards robert ...and thank you all for joining in .brilliant .
Last Edit: Feb 22, 2019 19:35:14 GMT by ivanhoew
