Howdy !
I live almost in this part of the forum haha !
Suspect that I am not the first nor the last that sets terms of steering columns for Ford Sierra.
We started to pick off the steering wheel (which was a hell . ) Then we took the plastic plate to be fixed inside the hub of the horn , and after a bit work so ended it there.
When we start to get it in place with the fitting piece of plastic that was sitting there and tried to tighten the hub with the " arrow up" or at least tried to get it straight because I locked the steering column with steering lock in a straight position before we took apart the original steering wheel as pointing arrow on the hub at 11 if one sees it in front of them ... So not right in the middle: S
Well when we anxiously steering wheel and hub , and turned the key as the steering lock peel off so you could not swing properly either right or left , it felt like something was blocking, one side went more than the other , however . What are we doing wrong ? Someone who can answer and experienced the frustration ? : /
Grateful for answers!
