May 20, 2015 20:39:35 GMT
I'm going to look at a 1994 2.0 gl vento either tomorrow or friday, since i know naff all about vw's i need a bit of guidance on what to look out for. This will be my first daily retroish car. All pointers greatly recived
Sent from my GT-I9505 using proboards
May 20, 2015 20:59:03 GMT
Rust! Make sure reverse doesn't click loudly when you move (like a rollercoaster winding up the hill) Rust! Hidden under sill trims, around rear axle mounts. Rear calipers seized on/off. Glovebox probably won't work Electric windows probably won't work Engines are probably OK unless really leggy. If it feels flat and gutless check it revs over 5k - if not the dizzy timing is wrong and it's gone into limp mode , quite common after a cambelt swap.
May 20, 2015 22:04:48 GMT
Thankyou so much i will let you know how i get on
