having a big clear out most items are for the 200sx s13 unless stated otherwise or universal.
prices are posted unless stated otherwise. larger items collected from st.albans, hertfordshire
paypal accepted buyer cover fees
200sx s13 rare dmax style lights tinted 100posted
200sx s13 junyan rear lights modified to look better 50posted center panel needs finishing
stage 1 norris design ecu actually made for stage 2 70 posted ecu code is 44f picture off the chip at the bottom will include ecu
standard injectors 40 posted
4pin maf 35 posted can supply with pigtail
ca flywheel 20 collected
front strut bar sides no bar 15 posted
s13 bodykit 200
k&n air filter with adaptor plate 25posted
510cc injectors from evo 4 twin spray 100posted
s13...
z32 maf sold
wheel arch plastics......sold
under engine tray.......sold
alternator......30
ca cast manifold....10
ca crank sprocket.....10
rocker covers and cam covers .....20
ca sump.....10
ca wood ruff key.....10
fuel rail.......10
ca crank needs regrind big end failer...10
x3 ca pistons and rods ...10
CA Oil cooler standard ...10
ca rear window wiper motor ...10
Fuel pressure regulator standard ....10
ca tps ...10
x 2 knock sensors ....10each
CA Oil pump..... 40
CA oil pressure switch....10
CA Cold start valve....10
CA Thermostat Housing Pipe ...10
PAS Power Assisted Steering Pump Bracket Mount x2 ....sold
alternator adjustment brackets 10eqch
Water temp sensors dash and ecu for ca ...10 the pair
s13 fan stroud good condition 20
ca short braided water line.....25
socketed ecu faulty on my car but maybe ok on facelift? 20
gearbox plate......20
stereo brackets......10
s14
s14 front bumper......sold
S14 cast manifold.....10
S14 auto rad can be used in manual ...10
fog lights for s14 with brackets attached .....10
s14 flywheel ...15
random / universal
blitz dual sbc unit and loom only no solinoid ideal spare or if your unit is faulty 50
38mm flange x2 for external wastegate 10 each?
3" exhaust gasket new £2
loads off random s13 engine parts also
box off random silcone hose from 43mm upto 63mm in red and blues
also thick braided line and some an fittings
bodykit
dmax lights
s13 bodykit 200
s13...
z32 maf sold
alternator......30
ca sump.....10
fuel rail.......10
ca tps ...10
CA Oil pump..... 40
s14
s14 flywheel ...15
random / universal
bodykit
dmax lights
