I've got a 99 Audi A3 quattro 8l on coil over's. It is missing its front anti roll bar and does handle all that well as a result. From research it seems the arb should run under the drive shaft and mount to the strut rather than a loop over the shaft and mount to the wishbone like the FWD ones and mkIV golfs. Can anyone confirm this? My coil over's don't have a mount doe the arb presumably why it was removed. Has anyone ever added one? I'm thinking of a ring that can clamp between the nuts on the coilover but I'm worried about it wrecking the threads. Has anyone ever made a custom drop link to attach it to the wishbone? Any ideas welcome
Thanks
Adam
Thanks
Adam
