Got a little problem with my Rover P6, it's running newly installed Megasquirt with Ford EDIS4 doing the sparky stuff. Over the past few days after leaving the engine idling to get it upto temperature there's been an intermittent roughness and loss of power causing the engine to die. It's hard to tell if it's an ignition misfire or not, spraying water onto the exhaust primaries when it's in the process of not wanting to run doesn't show an obvious colder cylinder.
It has a wideband lambda fitted and that goes off the scale lean when the loss of power happens, sometimes the engine will slowly rev up and others full throttle doesn't do anything as it's about to stall. I've even plumbed a pressure gauge into the fuel rail feed and it reads 40psi when running. Watching my laptop with TunerStudio running I can't see anything obvious on the fuel side to cause it to run badly. I've got a new set of spark plugs I'm about to try out later. The car hasn't got an mot so I can't take it out for a blast either. It was only doing it when at running temperature hot, but I've just moved the cars round and it did it again, loss of power and stalled.
Now the odd thing is turning the ignition off and restarting fixes it? This is making me wonder if I've somehow broken the coilpack and it's imminently about to fail permanently. Anyone have any thoughts?
