Got a problem with the ignition circuit on my zetec powered herald, l have used the wiring loom from the escort, this should have made it more simple but l cant get the thing to start and it's getting to the point of shutting up the garage and throwing away the key or it'll end up on ebay as spares or repair.
The ignition relay clicks on and the efi relay will click on aswell but the fuel pump relay doesn't and when l turn the ignition off the ignition light stays on and both relays remain closed.
I've got the Haynes manual but it does not tell me where certain wires go
You can see the wire from the ignition relay is not shown and the ecu relay show the live going to the earth which has to be wrong, can anyone enlighten me please before set the fecker alight!!!
