Sept 7, 2015 11:53:17 GMT
Hello all,
It seems my fuel pump on the my E34 TD has decided to die, leaking enough fuel under the bonnet when running to make your wallet weep.... At first I hoped it would be the return pipes, although I know that the pumps on these are considered a weakness, I wasn't prepared for the cost of a replacement to be the GDP of an average African country!!!
Does anyone know of a suitable substitute for these? I am aware that they can be rebuilt, with varying degrees of success, I have heard of the Facet solid state fuel pump's being used, but seem to only be able to find the ones that are used for the fuel tank.
Any advice or help would be much appreciated please!
Thanks,
Ian
1971 Range Rover 1977 Jeep Cherokee 1982 W123 Merc 230CE 1992 Peugeot 405 TD Saloon 1995 Peugeot 405TD Estate (having a rest) 1990 Peugeot 205 CJ - For Sale 1985 Peugeot 305 GTX 1979 Honda Accord MK1 1995 BMW E34 TDS 1994 BMW E34 TD 1998 Mercedes 320 CLK
Sept 7, 2015 12:08:23 GMT
where is it leaking? mine leaked on the top seals, so I could change them without removing the pump, seal kit cost £15.
I don't think the pump is a weakness, they're just old and neglected, bio will kill the seals off too, its a VP37 as used on lots of VAG stuff, just in 6 cylinder variant.
Sept 7, 2015 12:18:17 GMT
So a 6 cylinder version of the VP37 will fit? It appears to be leaking from the top and sides, though maybe further investigation is needed and try just changing the seals first....?
BMW E34 TD Fuel PumpDez
@dez
Club Retro Rides Member 34
Sept 7, 2015 17:41:13 GMT
they're by no means an unreliable pump. in fact, ive never seen one totally fail, only leak a lot.
what they are is simple and easy to rebuild, a full upgraded seal kit that will take bio etc. is only about £15 iirc.
Sept 7, 2015 21:51:59 GMT
I rebuilt mine in situ, both daimond gaskets and the full top half. Be careful what you do with the top plate as it needs to go back in the same place as it controls fuelling.
Nissan Laurel SOLD BMW E34 Diesel SOLD Toyota Soarer 4.0 V8 SOLD Audi A4 1995 TDI SOLD Peugeot 205 1.9 TD SOLD Lexus IS300 SC
Sept 9, 2015 12:46:59 GMT
Rebuilding is the best way to go then....? Simple case of remove and replace gaskets in situ? I've not done a fuel pump before but how hard can it be?
Sept 9, 2015 12:49:54 GMT
not that hard on these as its semi electronic, just mark the top half as the bolt holes are slotted.
Sept 9, 2015 12:52:08 GMT
:-) Thank you!Are there any special tools required?
Sept 9, 2015 13:12:32 GMT
nope, just normal torx and allen keys and spanners.
Sept 9, 2015 22:15:35 GMT
Looks like a cup of tea and some chin stroking is required while I have another look under the bonnet then :-)
Smiler
I no longer own anything FWD! Or with less than 6 cylinders, or 2.5ltrs! :)
Sept 11, 2015 22:41:16 GMT
I wish I'd known this a few years ago when my 525TDS Tourer did exactly the same thing. That was an awesome car! It did have rotten sills mind. (check yours)
www.Auto-tat.co.uk'96 Range Rover P38 DSE (daily driver) '71 Reliant Scimitar SE5 GTE 3.0ltr Jag V6 Conversion '79 Reliant Scimitar SE6A 3.0ltr 24valve Omega Conversion '85 Escort Cabrio 2.0 Zetec - Sold '91 BMW 525i - Sold '82 Cortina 2.9i Ghia Cosworth - Sold '72 VW Campervan - Sold '65 LandRover 88" - Sold
Sept 22, 2015 11:40:11 GMT
My sills will need attention, but hoping to nip it in the bud.... I'm going to tackle this, any reccomendations on what upgraded seal kit to get please?
Also, any guides/hints/tips out there?
Thanks,
Ian
Sept 22, 2015 12:14:15 GMT
just get a bosch kit
Sept 29, 2015 10:05:38 GMT
Been mad busy with work, but sized this up one evening and the (stupid) question I have, is the how do I change the seals in situ with the manifold in the way, or do I need to remove that?
Sept 29, 2015 10:37:32 GMT
remove it indeed.
