Hello,
I wonder if there are any Ford minded people out there who can possibly help me with some aggro I'm having with my Mk3 Escort.
Its a 1984 Escort L, originally fitted with an 1100 OHV Valencia Crossflow engine, 4 speed gearbox, VV Carb.
In the last few months I have swapped the drivetrain with that of a 1987 MK4 Escort 1400 CVH donor car I bought. I have also upgraded other bits and pieces for the conversion, from other 80s Fords, as I have listed below. When fitting, the timing belt and tensioners, oil filter and oil, plugs, leads, dizzy cap, rotor arm, 3-piece clutch kit were all replaced with brand new parts
So...
My Escorts spec is now:
MK4 Escort 1.4 CVH Engine
Weber DFTM Carburettor (MANUAL CHOKE)
MK3 Escort 1.6 Engine Mount
MK3 Escort 1.1 Gearbox Mount (Original)
MK3 Escort 1.6 Injection 5 Speed Gearbox
MK4 Escort 1.4 Vented Front Brakes
MK3 Escort 1.6 Shocks and Springs
MK3 Escort 1.6 Radiator
Hopefully that gives you an idea of the state of the car. The donor MK4 I bought was running and driving until very recently, although I only drove it when loading and unloading when collecting it. Seemed OK.
Now, the problem I am experiencing is that when idling, it runs OK. You can start without choke, rev it as much as you like, and it will return to idle as normal. No coughing, no spluttering, no cutting out.
Drive it for a little while, and its got plenty of poke, responsive throttle and feels good. HOWEVER, after a little while, it will unexpectedly begin to play up. It cuts out when you are slowing down and changing down the gears. It cuts out when stopped idling, for example at lights, crossings and roundabouts. If you are driving along and, purely as a test, were to depress the clutch and select neutral, it cuts out. After its been doing this, then the car wont idle or drive without over half choke.
So far I have replaced the carb with an identical replacement, and done the following to both units with no success; cleaned and blown though the jets, replaced carb to intake manifold gaskets, adjusted the mix screws (resolves for at least one drive), cleaned and lubricated all moving parts.
This carb (Weber DFTM) appears to be abit of an odd one, I cannot seem to obtain a gasket rebuild kit for it easliy, if indeed that will make any difference.
The frustrating thing is that I cannot get this car to run nicely or reliably. Will replacing the carb with a different, more common unit resolve this, or do I have more serious engine problems? Maybe its not the carb at fault? I don't know.
I have always wanted to make this car XR3 spec (1.6 CVH), unfortunatley had to settle for a 1.4, but saw this as an opportunity to do a 'Version 1' of the car, then upgrade as I collected parts or encountered problems. At the moment, I feel so disheartened with it, as well as feeling like i have made a mistake financially. The car isn't going anywhere, it has incredible sentimental value so I need resolution to this problem. It drove better with a 1100 with a VV, if you can believe that!
I am considering several things, these are what I see as my options;
Buying an XR3 intake and carb
Replacing with a 1600 CVH as I originally wanted
Replacing with a 1600 CVH INJECTION (EFI/MFI/Very late 90s setup)
Replacing with a Zetec of some description (Probably beyond my skills- would have to farm out)
Does anyone have any advice to get me going and enjoying my car, or advice regarding further engine swaps? I would consider paying someone to help me work on it, although I'm not able to spend a fortune on it.
All input appreciated.
Thanks
Alex
So...
Thanks
Alex
