Hey guys
So I recently bought a 1989 3Gen EX Carb.
It has been sitting for a couple of years.
But a couple of months/ 200 miles before coming off the road it had a brake overhaul with new pads and disks up front and pads out back. (As per the receipts)
Ive checked the fluid and its nicely topped up / nothing leaking.
As I put my foot on the pedal it goes to the floor with very little resistance. I sat and pumped the pedal and it hardened up and had a good pedal but it fades away again to hitting the floor?
What should I do?
Cheers
Current retro - 1996 Alfa Romeo GTV / Daily - 2016 Nissan Qashqai Previous retros - Prelude, Integra, XR2s, XR3s, Orions, CRXs, Sylvia S12, S13, Pulsar, ZX 16v, 205 Gti, MX5, MR2 etc
sounds like a fluid leek.....
you sure your not loosing any fluid?
Well I was losing power steering fluid but ive fixed that now..
Brake fluid seems fine but ive not driven it since fixing the power steering fluid loss/fix.
Cant be related though?
Maybe just a brake bleed will sort it.
That, I'm sure is the Master Cylinder. When you put your foot down the fluid is escaping around the rubber seal, rather than being pressurized by it.
The good news is that it can be cheaply and easily rebuilt with a new seal and as long as it's bled correctly, it'll be as good as new.
'03 Porsche 996 C2 3.6 - Sort of Retro '84 Porsche 924 - Definitely Retro!
Thanks Steve - but would I not then see a leak / drop of fluid in the reservoir?
Nope, cause it stays in the cylinder, but works around the seal. I should have mentioned that I've already done one of these on a 4th gen.
Ah a man with experience. I guess there is no harm in trying to bleed the brakes first - just in case.
Any idea of where to get the seal from? eBay comes up with rebuild kits for bikes or full complete Master Cylinders?
dw1603
That, I'm sure is the Master Cylinder. When you put your foot down the fluid is escaping around the rubber seal, rather than being pressurized by it. The good news is that it can be cheaply and easily rebuilt with a new seal and as long as it's bled correctly, it'll be as good as new. They were supposed to have the brake fluid replaced every 24000 miles or two years. If this was skipped then the brake fluid would absorb moisture and the master cylinder could corrode causing fluid to leak back past the seals. If you are lucky, a reseal will work, if not you will need a new master cylinder.
Last Edit: Oct 6, 2015 23:30:17 GMT by dw1603: Spelling
bazzateer
Imping along sans Vogue
The M/C almost certainly has to come out to re-seal so why not just put a new one straight back in? At least you'll know it's good whereas with a re-seal you won't really know until it's all back together and bled with new fluid.
Ive bled the brakes and actually now seems to be ok? Fingers crossed it stays that way.
As mentioned above, did you bleed or completely flush the fluid? If not, would definitely be worth doing it. People (and a lot of garages) seem to think brake fluid never needs changing. I've seen stuff in ten y-o cars that looks like treacle!!
