Hello everyone,
I'm having a massive garage clear out as you may have already seen.
I have 35mm double insulated, high amp, extra flexible DC cable left over from jobs that is too short for me to use but certainly long enough to run front to back on any car.
I can supply it to any length you require with 2 crimped ends or 1 end crimped (assuming you are attaching the other to a screw type battery fitting). I can supply the lugs in a few different sizes 8mm, 10mm or 12mm.
Selling this at £4 a metre plus postage, including both ends crimped with your choice of lug or 1 end crimped and the other end prepped ready for a screw type fitting.
I only have it in colours blue or grey though unfortunately. I can wrap the ends in red electrical tape if preferred or if its a big deal I shall acquire some red heat shrink and cover both ends.
I also have black 25mm earth cable which I can do with crimps as per the other cable and this is priced at £2.50 a metre plus postage. I am happy to do short lengths if you looking to make up an earthing kit etc, however if is going to be a load of short lengths with loads of crimps we will have to agree some more beer tokens.
I'll only charge per what you want with a minimum of 1 metre. If you only want 1.5 metres, you'll only pay 1.5 times the cost of a metre etc.
Again I'm trying to do this cheap to benefit the few car communities I am a part of.
Any questions, ask away on here as they may benefit other users, anything you want to order, send me a p.m.
Cheers guys and gals.
