steveg
Dec 14, 2016 19:55:17 GMT
I've been busy doing stuff for the children as usual. My daughter wants to do some karting now so I bought this. It needed a fair amount of work doing to it and this is a picture of it after I put it together to see if I had all the bits ! The brake caliper mount has been reworked at some time, I didn't see it straight away as it was pretty dirty and and recent powder coat was hiding a lot. The big chunk of steel behind it is the new axle bearing mount I made, not finished in this picture but I will add some more especially as it's so easy to do so now.
steveg
A bit of an update on this as I have been busy over Christmas ! Most Children start out on Honda Cadet karts but as my daughter is now too tall for one of those I starting thinking about getting something bigger but most options seem a never ending spending spree or just cost a huge amount to start off with. My intial plan was to get a Honda GX200 but for her age and experience there isn't anywhere much she could have used it. Next plan was a smaller GX160. She will be able to practice at Thruxton kart track which is just up the road and when she has got the hang of things a bit more possibly take part in some schools racing. Schools karting has been around for years and was set up for those not able to afford to buy and run a kart on their own. It was intended that school teams would build a kart from scratch although this doesn't happen a lot now due to the fact most schools no longer have decent workshops to do this sort of thing now. This is the important thing I needed for use with the Honda engine. The Honda engine has the chain drive on the inside so there needs to be clearance sor the rear sprocket and clutch. Overall the chassis wasn't too bad but had a couple of problems one of which was the brake caliper mount I posted the picture of before. At some point before it had been powder coated the original caliper mount had been either replaced or moved and the chassis had a crack in it near the axle bearing mount the other side. This one shows where the chassis had been repaired. The original brake caliper wasn't in the best of health so I decided to buy a new one and a matching disc and carrier. Once it was all set up and the new mount for the caliper made up I cut the original bracket off and tidied up the chassis. This is the finished article. Very glad I have a pillar drill bit it still involved a lot of cutting and filing. You can also see the strengthening gusset I fitted and there is a matching one the other side. I got a local paint company to match the original powder coat and put it in a aerosol so I could spray a small area. The other side was a bit more of a mess as I found the main tube had split lengthwise. I ground out the crack and welded it up, then ran an extra weld along the whole length of the gusset and carrier. Bit difficult to show with the engine fitted ! This is pretty much how it stands now. Almost finished it just needs a chain guard and a disc protector fitting. One thing I did have to modify was the throttle pedal. As standard there is far too little travel on the pedal so I added an extra loop nearer the pedal pivot. That probably won't make a huge amount of difference with a bog standard engine but hopefully as my daughter gains confidence we might do some tuning. I decided to get a new standard engine. I am hoping with regular oil changes it will last forever but will have to wait and see. The mounts were bought off ebay and allow the engine to be moved outwards to gain extra clearance if needed. I have moved it over as far as possible to save it hanging off the side too much. Not sure if this will help much but it's closer to where a two stroke would be fitted. The chain guard turned up today so I will get busy making a mounting bracket for it and then it will be time to try it out. I bought the seat so my daughter had a bit of room grow a bit which was a bit of a mistake as I can't fit into it ! I did find if I took a jumper off and only had one pair of joggers on (it's been cold in the garage) I can just about fit into it but it isn't comfy. I will have to sort out another seat I think.
I would suggest reading the regs of any series you plan to enter, as some clubs do not allow powder coated frames. i only came across this pearl by accident when i was looking into racing a historic kart that i was planning to buy.
HTH Andy
steveg
Jan 10, 2017 14:15:11 GMT
I would suggest reading the regs of any series you plan to enter, as some clubs do not allow powder coated frames. i only came across this pearl by accident when i was looking into racing a historic kart that i was planning to buy. HTH Andy That sounds a bit odd as I would have thought most chassis were powder coated from new anyway. With any racing you have to follow the rule book. If we were planning on entering any of the big race series I think the welding I have done on the chassis would prevent us. Just getting out at practice sessions and having some fun will be enough to start with. For Schools karting the emphasis is on making sure the karts are safe, there seems to be a bit more of a common sense approach or at least I hope so ! For now I think the kart is actually ready to use. I had to do a couple of bits including fitting a cheap rev counter so we can see if we have the gearing anywhere near correct. I had to fit the chain guard which ended up a bit of a pain but I managed to do it without having to shift the engine over. These come as 1 piece mouldings so I had to chop it and make a few brackets to hold it all together again.
Last Edit: Jan 10, 2017 14:16:21 GMT by steveg
Jan 10, 2017 14:58:30 GMT
Cool. Will you test drive it anytime soon?? Video it anyway, please
Jan 10, 2017 21:49:45 GMT
I would suggest reading the regs of any series you plan to enter, as some clubs do not allow powder coated frames. i only came across this pearl by accident when i was looking into racing a historic kart that i was planning to buy. HTH Andy That sounds a bit odd as I would have thought most chassis were powder coated from new anyway. With any racing you have to follow the rule book. If we were planning on entering any of the big race series I think the welding I have done on the chassis would prevent us. Just getting out at practice sessions and having some fun will be enough to start with. Is the powder coating rule because any chassis cracks could be hidden underneath it? Can't think of any other reason.
steveg
Hopefully my daughter will give it a try soon, might just see what the clutch works like as it is adjustable on the drive to start with. Unfortunately unless I wear very little I can't fit in the seat and my weight might cause the clutch a problem will have to see.
I can understand why powder coating might be banned as it certainly covered one of the cracks on this chassis. Saying that I have seen fairly new but well used chassis with cracks in but they still get powder coated from new. Pretty sure chrome plating isn't allowed on critical parts like suspension arms for motorsport.
steveg
My Daughter had an inset day on Friday and we decided it might be a good plan to go to Thruxton Kart track to give the kart a try. It's about 10 minutes from up and the track is very good. The only disadvantage is that if you take your own kart and anyone turns up to use the hire and drive karts you have to wait until they have done. Our plan was that because it was so cold nobody else would be silly enough and apart from just 2 children on the smaller track we had the place to ourselves. My daughter had a quick go on the small track just to test the kart but the gearing isn't right and she couldn't really get any speed up so over to the big track it was.
It took a few laps to work out the track as it's quite long. I've only been out on it once and got a bit lost so she is doing better then me. Sorry for the odd sniff it was very cold ! There was a couple of chuckles as well, first one was because she worked out the lines through some of the bends I was filming and then she got the back out a couple of times !
Last Edit: Feb 13, 2017 9:49:18 GMT by steveg
Feb 13, 2017 23:02:09 GMT
Nice one. It looks a damn sight more of an interesting track than some of the modern F1 venues!
TS
Feb 18, 2017 15:28:29 GMT
What happened to the shortened BMX?
steveg
Feb 18, 2017 22:02:55 GMT
What happened to the shortened BMX? It's up the roof of the garage and didn't get much further unfortunately. To make it rideable I needed to lower the bottom bracket or fit a really short crank. I was trying to think of a way to make the new bottom bracket pivot to allow chain adjustment and then fix the rear wheel as well. It was taking so long my son grew enough to ride a 20" wheel mountain bike style bike his cousins gave him so I ended up building this up for him. Thats the trouble or perhaps the good thing with children, they tend to grow and it means you have to keep making new stuff for them !
steveg
Feb 18, 2017 22:08:25 GMT
Nice one. It looks a damn sight more of an interesting track than some of the modern F1 venues! It's a brilliant track but they are only allowed to run 4 stroke karts there due to noise restrictions. I'm hoping we might get down there again some time next week as it school holiday time. A bit more heat in the tyres now it's a bit warmer should help things as well.
steveg
Apr 12, 2017 12:05:44 GMT
My daughter took part in her first proper race at the weekend and had great fun. For her first time out she did really well and finished about half way in her class. To make things even better she won the Best Novice trophy. I think all that is holding her back now is the speed of the kart so I had better get busy ! If anyone has a son or daughter who is interested in taking up karting it's worth having a look at what NatSKA do. NatSKA stands for National Schools Karting Association. The idea is that schools set up teams and can help by providing a kart to use for beginners but the biggest benefit for us is that we can race using a single Honda engine on a larger kart chassis and this really keeps the cost down when compaired with what else is available. This is their website www.natska.co.uk/
steveg
Apr 16, 2017 14:19:59 GMT
I've not been happy with how the engine fits on the kart as the two mounts don't actually hold the engine square on the chassis. I wanted to move the engine back and up a little so made a plate up to hold the two mounts square. I took the opportunity to chop some excess off them at the same time. I put the holes in it so some air could still get to the sump on the engine. The fancy shape of the holes on the end isn't me being clever, I drilled them in the wrong place slightly and this makes it look better ! This is actually the first time I have used my little milling machine properly. This is it the mill after I had bodged the holes up !
Last Edit: Apr 16, 2017 14:27:26 GMT by steveg
steveg
Apr 16, 2017 14:38:19 GMT
My son is a keen follower of Roadkill so when we spotted a very dirty 55 Chevy for sale at Race Retro he decided to buy it. It looks much better after a clean up but the chrome is a bit yellow plus it's far too standard ! He is going to build it gasser style so a new set of wheels was needed. Standard size front wheels with the whitewall removed ready for the rears. The rear arches are going to need some work ! We haven't decided if the chrome strips need taking off yet. If we do I will have to fill the holes in the sides. looks better with the bumper removed as well. Other plans include a repaint and engine swap. Getting a suitable engine isn't easy but by using a larger scale Chevy small block we will actually end up with a big block !
steveg
Ah the Blasphemi, any more pictures of it? How did it turn out?
It's a work in progress at the moment. Been busy with karts A kart update would be good if you've got one, please.
steveg
It's a work in progress at the moment. Been busy with karts A kart update would be good if you've got one, please. Thanks for the interest Georgeb. The racing my daughter does starts at the beginning of the school year and our first race of the season was at the weekend. Part of my busyness has involved buying a van to transport the kart and provide somewhere a bit more comfortable to sleep overnight if we need to and I have ended up with a pretty tidy Transit Minibus. This has made thing so much easier as the kart fits straight into the back of the van without needing to take anything off. My daughter did quite well throughout the day. Just before the last session it rained so we fitted the wet tyres. Some went out on slick and had a lot of trouble even those on wet tyres were struggling but Jemma went past everyone. We have managed to stumble on a very good set up for wet weather so really need to work on the kart set up for the dry, some newer more suitable slicks might help as well ! The problem we face running the little Honda engine on a senior chassis is that there just isn't the power available to get the tyres working properly. One way round this is to pump them up hard but but you end up with what is effectively a narrower tyre. I'm trying to find something with a softer compound that might be more suitable.
Last Edit: Oct 2, 2017 11:14:47 GMT by steveg
