Nov 16, 2015 12:42:54 GMT
Just recently bought one and after hunting around I found one at reasonable price in the range
The do 2 different sizes and the bigger one is 49.99 and other is 34.99 which is what I got
Can't fault the jump pack at all however the built in compressor isn't really much to write home about as started smoking after 2nd wheel
Built to a standard ready to be modified to perfection
1995 Charcoal Rover 220 GSIT (WIP)
bortaf
Nov 16, 2015 13:30:52 GMT
istopped buying jump packs a few years ago, i use an ald merc battery with the leads from my last jump pack on it Like this but bigger, cost free (customers old battery)admittedly i'm tight as a nuns chuff
R.I.P photobucket
Nov 21, 2015 20:36:46 GMT
I have a mini Li-ion one, it starts my flat Landcruiser 4.2TD much to my surprise! It is impressive I have to say.
Resident Toyota Geek Current Fleet: HDJ81 Landcruiser, GZ20 Soarer, JZX81 Cresta
Neil
Some great info, thanks for the replies. I'm gonna spend some time having a good read on reviews tomorrow and order a small lithium ion jobbie.
omega
I have a mini Li-ion one, it starts my flat Landcruiser 4.2TD much to my surprise! It is impressive I have to say. have you got a model number and where can you get it from? seen loads on ebay but cant make up my mind what to go for cheers
skozra
Nov 22, 2015 12:33:52 GMT
I've bought one of those DB Power ones from Amazon. They get real good reviews and the one I received is solid, remarkably small but seems really well made etc. Will it work ? Well the first time I get a flat battery, if I get a flat battery, then i'll know I guess.
My last experience with a 'booster' like this was an old Kingavon one back in the early 90s. It was heavy. It was useless, as even when it was supposedly fully charged and connected up it was just like hooking up a flat battery to your car's flat battery. Click-click-click-click-click.......
93 Volvo 240 Torslanda Estate, 01 Subaru Impreza WRX Saloon & 86 Ford Capri 2.8i (with Weber 38 carb fitted)
Nov 22, 2015 14:32:31 GMT
omega
Nov 22, 2015 16:48:21 GMT
thanks there seams so many with so many different specs and iam sure some are not very good so thanks for the heads up. have shown my kids so maybe santa will but one in my stocking
Nov 27, 2015 21:04:46 GMT
I bought a set of 3000F ultracapacitors. Put 'em in a box, add a heavy Anderson connector via some 50mm welding cable, and a little momentary push switch to a volt meter, and a nice long pair of leads (Anderson, welding cable, and a pair of honking gurt Russian crocodile clips) and there you have it. Starts our 4l telehandler 8 or 10 times, recharges in about 4 mins from any running vehicle, and weighs maybe 6kg. Will put up a couple of photos at some stage if you want. Got any more details on this? How do you control the output?
Koos
heathrobinson
Broken everything
Club RR Member Number: 111
Booster / Jump starter packs.heathrobinson
@heathrobinson
Club Retro Rides Member 111
Nov 27, 2015 21:47:18 GMT
You don't need any control, just as with a battery the starter draws what it needs. Got the ultracaps from eBay, just search for ultracapacitor. You could use much smaller ones for a car.
Just get a type 096/100 battery and keep it charged. Jump packs won't work on a completely flat battery, they'll work on one that needs a bit of help but a flat battery the can't help. Problem is that they're rated a different way to regular car batteries so when they brag about 1000amps, thats equiv to a 300A battery off a 1.4 astra. Also when you're trying to start a car with a flat battery the flat battery tries to take all of the current, as a result non gets to the starter. Depends what jump pack you have, my Snap-On one hasn't failed me even started large engine cars with a battery reading less than 2volts.
