Ah! I see you also have the MPFI spider intake from 87-up! Thats a good thing, those are the final reincarnation of the engine and not only look the best but also go the best Be sure to have the heads pressure checked, they LOVE to crack between the valve seats (which can be fixed of left alone, its not that bad) or crack into the exhaust ports (which means it's time for a new head). The heads will be stamped EA82T which can be underlined, boxed or nothing at all, if I recall, the boxed ones are the best, they are a post production update as a replacement head and seem to be stronger. Have you checked the turbo? If it has any play in it, I seem to recall it uses the same core as ford probe and CX500 (YES motorcycle!), the RHB5 or something like that. You could also upgrade to a TD04 but thats another story The engine looks really great all painted up! Just remembered something, between the cam carrier and head is a rubber o-ring, this MUST be a metal reinforced O-ring, a normal one gets blown out. Best bet is to order it from the dealer.. I mean, harass your parts guy Fel-pro offers an engine rebuild gasket set, very complete and high quality, it's also a perma-torque head gasket which is nice.
nigxl
Dec 17, 2015 15:20:22 GMT
I had one of these back when they were almost new. Parts were scarce even then !!!!
Dec 17, 2015 16:27:01 GMT
The '80s on four wheels. Great design but looks like a long haul resto. As you're in the Subaru bosom you've got a better chance of finding the last of the parts! I looked up the 'weird dashboard' as suggested by dikkehemaworst . Do you have this? Looks nice - like a spaceship - but quite a lot to go wrong I reckon! Good luck. This looks a lot like the dash in my first car:
If at first you don't succeed........ ....Don't try skydiving!
Dec 17, 2015 20:45:12 GMT
Ah! I see you also have the MPFI spider intake from 87-up! Thats a good thing, those are the final reincarnation of the engine and not only look the best but also go the best Be sure to have the heads pressure checked, they LOVE to crack between the valve seats (which can be fixed of left alone, its not that bad) or crack into the exhaust ports (which means it's time for a new head). The heads will be stamped EA82T which can be underlined, boxed or nothing at all, if I recall, the boxed ones are the best, they are a post production update as a replacement head and seem to be stronger. Have you checked the turbo? If it has any play in it, I seem to recall it uses the same core as ford probe and CX500 (YES motorcycle!), the RHB5 or something like that. You could also upgrade to a TD04 but thats another story The engine looks really great all painted up! Just remembered something, between the cam carrier and head is a rubber o-ring, this MUST be a metal reinforced O-ring, a normal one gets blown out. Best bet is to order it from the dealer.. I mean, harass your parts guy Fel-pro offers an engine rebuild gasket set, very complete and high quality, it's also a perma-torque head gasket which is nice. I have heard of the cracks in the heads but its a good thing a have 3 complete engines xD, my turbo is completly dead its cracked 3 places in the exhaust housing and the wastegate arm is snapped, so I'm planning on going to use the TD05-16G or a TD04.
1988 Subaru XT 4WD Turbo- White on going total restoration. 1988 Subaru XT 4WD Turbo- Lake blue as a parts car. 2007 Subaru Impreza 1,5- Sold. 2006 Subaru Forester 2,5xt Aut. Van- daily driver. 1990 USDM Subaru Legacy 2,2 turbo- project
Dec 17, 2015 21:12:08 GMT
Dec 22, 2015 19:30:40 GMT
Jan 18, 2016 20:12:02 GMT
Jan 19, 2016 10:22:47 GMT
Looking excellent so far...fast becoming one of my favourite cars on here.
mattiwagon
Just got a work truck
Jan 19, 2016 21:43:40 GMT
Dude when your done this is going to be an awesom car!
If they cant be nice f**k em!
84 low t25 panel 1.9td beige and rust combo 97 Goped Bigfoot G260RC with clutch conversion 97 Impreza turbo 2000 builders wagon 76k sold 04 Fabia vRs 50mpg pocket rocket 04 battered T5 pickup in blue! Chainsaws lotsa Chainsaws
sparrowhawk
Subaru owner, also tinkering with a Mk2 Fiesta among other things
Jan 26, 2016 13:43:30 GMT
LOVE this thread!
I had a Subaru XT Turbo as my first ever car! I wasn't able to drive it - as a 17 year old in the UK with a Turbo Subaru, insurance was an issue!!! But I had a great time driving it around fields with my dad, even got it sideways a few times. Then had to join reality and got a 1.0 Vauxhall Corsa!
I let the car go for a criminally low price. It was a two-tone car Blue, with a white lower half, and I believe it was on a C-Reg. This was probably around 2004 or 2005. Hopefully its one of the very few still on the road in the UK. I will track down a pic if possible.
Keep up the good work. Not the easiest car to work on I expect, so good luck!
Jan 27, 2016 21:34:03 GMT
LOVE this thread! I had a Subaru XT Turbo as my first ever car! I wasn't able to drive it - as a 17 year old in the UK with a Turbo Subaru, insurance was an issue!!! But I had a great time driving it around fields with my dad, even got it sideways a few times. Then had to join reality and got a 1.0 Vauxhall Corsa! I let the car go for a criminally low price. It was a two-tone car Blue, with a white lower half, and I believe it was on a C-Reg. This was probably around 2004 or 2005. Hopefully its one of the very few still on the road in the UK. I will track down a pic if possible. Keep up the good work. Not the easiest car to work on I expect, so good luck! Thanks Is the scooby in your profile picture yourself I love the blob eye sadly i don't get to work on to many STI here at home because they cost 65.000£ new but i do work on a lot of Forester XT's wich ain't bad either
sparrowhawk
Yeah the Blob eye is mine. Not many people consider it Retro, so I haven't posted anything about it on here! But I'm planning to start working on my Mk2 Fiesta soon. I'll keep an eye on this thread. Would be great to see a restored XT back on the road, its such a genuinely rare car. I look forward to some pics of that some time in the future
mhuk
Jan 28, 2016 15:06:19 GMT
My friend had one when we lived in NZ. It's like captain Scarlett's car! Loved it.
Spitfire with a mx5 turbo engine
Merc W210 on veg oil running water injection.
Nov 13, 2016 14:52:48 GMT
oukie
Nov 13, 2016 16:44:22 GMT
Last Edit: Nov 13, 2016 16:45:27 GMT by oukie
Mr2 mk1 x4
Honda Accord 2.4 Executive (luxo barge)
Nov 13, 2016 20:07:31 GMT
That doesent look to bad sadly automatic and the front wings look a bit rough
quackshot
...friggin' cars...
Nov 13, 2016 20:26:27 GMT
I love these! Good work dude If anyone wants one, I know of a almost immaculate 1 owner model in a warehouse in hertfordshire. It's a N/A fwd model though.
smeden
"Full throttle until you see God,then shift to second"
Nov 16, 2016 12:17:44 GMT
How about an update Martin!
Jaguar xj6 S1 swb manual VW Bay Camper Audi A3 1998 1.8 VW Beach Buggy (sold) Ford Mondeo mrk I RS Celebration (written off) Ford Escort Mrk II RS 2000 (rust in peace)
Apr 13, 2019 12:03:03 GMT
Amazing! Well done fella
