foxy99
Nov 25, 2023 13:57:02 GMT
Last Edit: Nov 25, 2023 13:58:40 GMT by foxy99
foxy99
Nov 28, 2023 16:31:03 GMT
So I'm now repairing more fiddly bits. Still on the tailgate but will be using same technique on the longer boards if this works out ok, which I think it will. So board #2 which hasn't had any repairs yet had most of the bottom of its outer edge missing but the inner was fine. Instead of cutting the whole bottom off I used a wide router bit to remove all the rotten bit. This produces a really clean edge to work to so afterwards it was just a case of cutting a thin piece of wood of a suitable length and gluing/clamping it into the space left by the routing operation. The only issue was I cut it too short (looked at wrong pen mark on the new wood) and I didn't want to find another piece so I just stuck it in with the bit that I cut short in error. Once it's dried all I need to do is shave the new piece flush with the original board then put a groove back in it. To make things more interesting I have included a pic from when I bought the trailer in August showing the board(s) I'm posting about here working on bottom of board 2 right now decayed part removed neatly with router inner face of same board is still sound new piece of (oversize) wood offered up including my error cutting it too short after marking correctly new piece glued and clamped in
Last Edit: Nov 28, 2023 16:31:26 GMT by foxy99
foxy99
I didn't risk routering the last repaired bit tonight after taking the clamps off as the excess glue is still soft. It is like -3 degrees (or -1 when it's warmer) the now so that won't help and mb the glue only dries when there is no air about (as it stays soft in bottle) but I wasn't taking any chances and started on another bit. This is the 2nd-from-bottom board from the front panel (#3). I said the front wasn't bad but this board had a lot of rot on its upper edge and you're wondering what the hell you are doing trying to save a bit of scrap wood but after cutting the rot out (with saw) you can see how sound it is. I didn't use the router here as it was soft right thru but also because my router only cut's a certain distance in and this board needed more than that removed. Doing the cut with a saw meant a lot more time spent afterwards (with a plane) trying to get very clsoe fit between the old wood and the new - which did have a straight edge. It was part of a rafter or similar from an old building that I got months ago and used to repair my lock-up door frame. The slither that came off it was ideal for this repair. Interestingly after planing the very old wood it looked just like some cheapo CLS stuff from B&Q. Anyway I got it done and it's now glued and clamped so the queue of bits to be repaired is slowly going down and am now thinking I could use (dark) wax on the wood rather than varnish or paint. They seem to use that all the time on Salvage Hunters etc but I've never had any and too tight to buy various tubs to experiment working on #3 board from front panel now outer face of board doesn't look too badbut other side tells a different storyrot cut out shows surprisingly sound wood remainsnew piece cut from remains of ancient rafter glued & clamped - other side shows old wood planed looks like cheap pine now
Last Edit: Nov 29, 2023 1:01:52 GMT by foxy99
foxy99
So I did a bit more on the boards yesterday and today. It's taking a lot of determination as the weather was vile today and my feet were soaked right thru from some earlier activity but I got a new bit fitted to the lower edge of the top board from the tailgate. Yesterday I planed down the last 2 repairs (which were board #2 from the tailgate and board #3 from the front panel) and am very pleased with the way they turned out. They still need to be routered tho (for the T&G aspect). Today was doubly depressing as I spent the afternoon helping the Gaffer empty decades of junk from the loftspace above the barn opposite mine. A lot of it was his deceased son's old stuff plus loads of wet materials from an unfinished project at re-roofing that barn and making a bit 'recording studio' in the attic. I know I could fix all the leaks in the slate roof and it would be a brilliant space for me to move all my motorbikes into but there's no time for all these sort of plans now due to his age so basically it was just freezing, wet, futile-feeling day but I forced myself back into the container to continue repairing scrap wood and trying not to think about the other 6 cars, 8 motorbikes, 3 pushbikes and 3 trailers that I will do up 'one day' But yeah the bit I worked on today is the piece which had its split top section glued back on but has 2 bad/missing areas on the bottom edge so I started with the longest one, cut it out as square as I could and cut another bit from the old rafter and glued it in and clamped it. As I keep saying the list of bits to repair keeps getting smaller and There's not much left to do on the frame so it could be all back together this month. I actually found myself working on the trailer frame yesterday. As I was grinding away at the rust on the inner rails the Gaffer came in (to see if I'd help clear the hayloft today) and said 'what you doing?' 'Em wasting my time?' 'Are you not freezing?' 'yeah but it'll be like this till March and I'm not sitting in my flat freezing instead' But yeah I need to weld the rear upright back on (pics not posted yet of it removed as they are in my new camera internal memory and I don't have date-transfer cable for it), finish painting it and stick the axle back on then fit the wood and we're done. end view of repair to bottom of #2 tailgate board which had rot cut out with routersame piece. new wood was not full thickness of board as only one face was soft quite pleased that repair to bottom edge didn't need to go past the click-a-print thing very pleased with how new wood spliced in to the groove part of this board repair to top edge of #3 front board differed as it was full thickness. Fr & Rr shown groove needs to be routered in bad bit cut out of bottom edge of top tailgate board and new piece ready to glue in glued and clamped
Last Edit: Dec 4, 2023 20:49:39 GMT by foxy99
foxy99
So a bit more done today. It was colder today but totally dry and we finished gutting the hayloft so things felt a bit cheerier. The hayloft would be a brilliant (3rd) workspace for me but I think it would only be fair to have to pay more rent and I'm kind at my limit (£70pw - which is £3650 a year!). It's about 40 foot long and mb 20 wide. 15' anyway but the eaves of the original roof are quite low so there isn't a huge amount of headroom at the sides. Apologies for anyone who doesn't know what I'm on about with the Gaffer and The Barn but I've mentioned it so many times on other threads that I assume everyone knows. unfinished hayloft conversion after taking 3 trailer loads of junk from it to dumpdark picture despite 4 large Velux windows and huge vertical window being thereSo, yeah I got the bits from 29th-4th routered but no photos as still need to put 45 degree chamfer on the edges and also the first sort of half-thickness rot-routered repair on one of the long side boards. I mentioned above that my router wasn't deep enough to cut as far into the board as I wanted to but found a way round it today.... The adjustable plastic fence on the router looks kinda fancy but it's effectively nothing and is actually not straight (it bows inwards slightly). So I took it off completely and replaced it with a bit of CLS clamped to the table. This was a false start tho as it wasn't wide enough to offer much adjustment without slipping out the clamps. I therefore changed it for a flat board (one of the ones for the green trailer made from reclaimed doors) and it worked fine. Just like the repair on one of the short boards I routered the rot out the soft face but left the good face intact. As I was going down I could see, and smell, that the wood was sound so didn't even go as afar over this time. After that it was just a case of gluing in a thin bit of wood carefully cut to size and gluing/clamping it. I've just about run out of glue so will need to get some more as there still several bits to deal with one of the first boards I worked on. started cutting full thickness of rotten edge out with saw before realising could just remove rot with router plastic 'fence' removed from router table to get more 'depth'CLS clamped on the use as fenceCLS gives too big a gapflat board gives a little more scope for adjustmentand more suitable gap for this jobclamped board to give approx 35mm from outer edge of board to outer edge of bladewhich matches roughly what I wanted to remove from board1st (shallow) pass is pretty close to my inked linecut with router is much truer than doing with sawnew bit glued in and clamped
Last Edit: Dec 5, 2023 23:34:29 GMT by foxy99
foxy99
Dec 14, 2023 21:22:34 GMT
So I've had the work on the trailer interrupted a little as the tax & MOT are out on my car and on Saturday (4 days ago) I started dealing with several things I have needed to do to it. As it was in bits and waiting on a part coming I ended up pulling the turbo out on Tuesday night, to clean it. Been wanting to do this for over 2 years but thought it would be one of those jobs that could go badly wrong so kept putting it off. It took around 7 hours to get it out but that was outside in the dark and rain and I think that slowed me down. Anyway. The point of it is I returned to work on it last night and couldn't get the 2 halves of the turbo apart and having walked over an hour to get there I had to do something to make the journey worth it so turned back to the trailer-boards. I finished planing & routering the last 2 repairs including putting a chamfer on the edges of all the boards which have had new 'groove' parts put in. Doesn't seem to be as many on the 'tongue' edges. Once that was done I had to pick the next bit to tackle and plumped for one of the boards from the front panel. The top outer edge of board #2. This is a tongue edge and it doesn't strictly need fixed as the tongue is still there and strong but for some reason the shoulder (?) below it was all missing but no signs of rot. It just looked bad. I'm getting used to these repairs now so just cut out enough with a wide router bit down part of the thickness of the board and glued/clamped new piece in. As the bit going in didn't need to be thick I spent most of the night planing it down to just thicker than it needs to be. I didn't have a new bottle of glue so cut the old one open to find enough. and more, to do this repair. Once it's dried it will be easy to router down as I'm not actually recreating a tongue or groove. Despite having two good cameras with me I didn't get many (any?) good pics last night. I'd forgotten the memory card for the 12.1mp camera that I've been using last couple of weeks and had actually taken my best 14.1 camera down which I've not really used yet so turned to that and it didn't go well at all. The battery was low and all sorts of weird things were happening and I couldn't find a macro function on it (all my other cameras have had that) but had to persevere as the memory card in it doesn't fit in the other one. And the batteries don't swap. trailer repairs interrupted bu removal of turbo from my dailyrepair needed heretop (tongue) edge of board is sound but a large part of shoulder seems to have split offdamaged/worn part of board cut out and loaded with glue need to get more glueshavings from creating a thin repair piece which is now glued/clamped in
foxy99
Dec 16, 2023 16:21:20 GMT
So the repairs continue - as I'm still having no luck opening the turbo I keep saying it but I am getting there with the board repairs. Last night I went back to board #3 of the tailgate, which am sure will be the board with the most repairs done. It has already had 2 new bits put in but at the bottom edge was missing the outer parts of the groove on both faces. A long bit on the outer face and a shorter bit on the inner. So it was just a case of routering out the rot again (on both sides) then gluing in 2 thin strips of wood. I could have cut out the full thickness of the board but found doing this previously you don't get such a neat line as you do with the router bit. Also didn't spend ages planing down a thick piece of wood to make thin repair pieces. Instead I sawed a bit of wood lengthwise to make two thinner bits. Was using the 14.1mp camera again and it was working fine with a charged battery in it but still getting rubbish close-up pics. I had a look at the instruction manual online (Sony Cybershot DSC-W370) and couldn't find any reference to Macro Shooting. On all my other cameras there is a button for macro (looks like a flower) and the cameras usually self-macro if you go up close to the subject. The flower icon appears in the LCD automatically. Think I'll need to revert back to the other camera and use this one for my work - where I don't need macro. I also got the long repair from previous post planed down last night (outer face, top edge of board #2 from front panel). It's looking good and just needs a little routering to make the groove correct width and add the chamfer on its edge turbo still not separating from manifold despite introduction of heatdealing with this bit now. also similar on other side but shorter length work needed on lower edge of outer face and same on inner face inner face after routering and same on outer face thin repair pieces made by sawing a bit of wood down middle rather than using plane outer repair glued and clamped and inner repair to board #2 from front panel planed level
Last Edit: Dec 16, 2023 16:24:03 GMT by foxy99
